Standalone install w/ custom harness
Darwin
Has thanked: 116 times
Been thanked: 74 times
Hey everyone,
Starting late last year I decided that I wanted to change the Standalone that I was running. I had been running an Electromotive set-up for the better part of a decade, but it had some nuances that I hadn't been fond of so I made the decision to change to a newer one.
The decision on what manufacturer you want carries a lot of variable with it. I had looked into Microsquirt as a friend did that for his 16v turbo build, but wasn't overly happy with some aspects of it. A good friend of mine ended up recommending a Link ECU, and after looking at the various models that they had, I settled on the Link Monsoon-X. It fit what I wanted from a capability vs. cost standpoint, and it also had an integrated MAP sensor, which meant one less thing in the engine bay!
One of the main points of this thread will be to share what components I chose, where I bought my components, where I bought the tools to make the harness, as well as where I bought harness supplies. I don't intend this to be a step by step guide on how to build a harness, but anyone is more than welcome to PM me if they have questions on what I did or why. The typical disclaimer of "I'm not an expert, just an enthusiast" applies to everything here! :D
One really nice thing about Link was that you could purchase premade looms in various lengths depending on your need. Their ECUs require either a single A-loom or an A and B loom depending on capability. The Monsoon-X only need the A-loom so I began with a 2.5m A-loom harness.
Now I had to sit down and start figuring out what sensors/components I needed, as I wasn't going to use anything from the previous standalone install. I'll share a link to individual components if anyone wants to check them out for themselves.
  • Crank sensor mount - 944 Enhancement
  • Cam Sensor reluctor - VW/Audi
  • Cam sensor mount - 944 Enhancement
  • TPS adapter - Rabbit Wiring Solutions (not sure if he's making them anymore, though)
**NOTE** I bought the MAC Valve off amazon fully understanding that it may not be genuine, especially given the price. Genuine valves are typically two to three times the cost of the Amazon one I bought, but worst case I can replace it with little money lost.
When it came to building the harness, supplies became a little harder to source. My main goal was to stick with components as close to factory quality as I could, relying heavily on Bosch connectors/boots as well as Deutsch DT connectors.
  • https://prowireusa.com/ - Great for Tefzel or TXL wire, shrink tube, as well as Bosch connectors, Bosch boots, and Deutsch connector kits.
  • https://4rcustomswire.com/ - This company is a great source for TXL wire in any color combination that you want/need. I relied heavily on them for the additional wire runs that I put into my harness so that I could keep sensor wires matched to what the factory had originally chosen. They even sell in lengths as short as 5'.
Tools:
Materials aside, you won't really be able to build a good harness without the proper tools. Here are a few examples of what I needed to get in order to properly terminate my harness:
Building the harness:
  • Wire - TXL, 18 and 20 AWG
  • Harness covering - Raychem DR-25 2:1 shrink tubing (1", 3/4", 1/2", 3/8", 1/4", and 3/16")
  • Branch sealing - Raychem SCL 3:1 and ATUM 4:1 adhesive lined shrink tubing in various sizes.
  • Harness labeling - A friend let me borrow his shrink tube printer so that I could label individual runs. I don't know how much these cost, and if it would be cost effective for someone building a single harness, but it really makes the final product look great.
This was the most frustrating, yet most satisfying part of this entire project. I had never attempted to create a harness of this scale before, and intimidation was a huge factor at certain points. I took my time, measured 30x, cut only when I was sure, and made sure to carefully map out the entire harness before I actually started laying wire out. Unfortunately I didn't take a whole bunch of pictures during the process. Most of what I can share are of finished branches, but hopefully they can help someone who may be trying this for themselves!
https://rbracing-rsr.com/wiring_ecu.html - Anyone attempting to build a harness really should sit down and read what is on this website. A great source of knowledge from people who build motorsports quality harnesses. I referenced it quite a lot as I worked my way through my harness!
The first obvious step was to get the old harness out so that I could begin laying in the new one.
harness removed.jpg (89.45 KiB) Viewed 1769 times
Then I could lay in the new harness and begin planning my branches. This was probably the most time consuming part of the whole process. I must have installed and removed the harness 20-30 times, carefully marking where wires went, and what lengths they needed to be. Whenever I figured out where I wanted a specific branch to lay, I added about 5 inches to the cut length to ensure I didn't make anything too short. I wanted to avoid having to splice in extra lengths, or have to replace wires outright due to a mistake on my end.
running branches.jpg (86.04 KiB) Viewed 1769 times
As I slowly figured out how long branches would be, I would feed them through shrink tubing and recover it onto the wires, being careful to make sure that branch markers further out weren't disturbed.
almost done.jpg (55.15 KiB) Viewed 1769 times
getting close.jpg (83.13 KiB) Viewed 1769 times
end result.jpg (52.18 KiB) Viewed 1769 times
When it came time to figure out coil pack mounting, I had to get creative. My old set-up used a custom made coil pack mount that was supplied by @chris white. I decided to tackle this myself this time, as I was beginning to learn sheet metal fabrication at school. With a little help from an extra coolant crossover, I fabricated a mount out of some sheet .090 and .040 2024-T3 aluminum. I think it turned out really nice! I gave it a final coat of satin black as well as a quick disconnect from the main harness so that the coils could be removed as a sub-assembly rather than having to disconnect all 4 individually.
coil mount 1.jpg (52.96 KiB) Viewed 1769 times
coil mount 2.jpg (42.16 KiB) Viewed 1769 times
Overall I am extremely satisfied with the end result given my experience level. I am still in the initial tuning process, but the car starts and drives better on just the initial tune than it did on my old set-up!
The link software has been incredibly easy to work in, and with some help, I'm hoping to have it back to 100% quickly! (If I can find the time outside of family and school!)
2012 VW Tiguan - Kinda stock
chris white
Been thanked: 175 times
Don’t forget ‘heat shrink solder connectors’ (search Amazon) …..very handy items!!!
chris white
Another very handy tool is the Dymo label maker with printable heat shrink tubing labels.
This looks great! Tons of great resources in that post too, thank you!!
I have a G4 Extreme and harness I was planning to use at some point, but never got around to it. If CA ever exempts '86 cars from smog, I might give it a go, mostly to satisfy my inner-tinkerer... I'm intrigued by the rabbitwiring 3D printed TPS adapter. I'd love to find out what material it is, and how hard it stays when then the engine compartment is full hot. Formlabs makes a high temp resin good up to 460F, so that's on my list to start playing with for under-hood parts like that... Wiring all looks top notch -- as does the whole thing. Now you have to dial it in and get to a dyno. :)
This also reminds me I think I promised to make you a SpeedoBooster, although it needs MAP sensor signal -- does your ECU have an output with internal MAP signal voltage?
I get the feeling this thread is going to end up costing me. I didn't know shrink tube printers were so readily available -- now I obviously need one of those :)
p.s., to Chris -- your emails are bouncing...
chris white
Tom wrote: Wed Sep 08, 2021 6:23 pm This looks great! Tons of great resources in that post too, thank you!!
Can you send me a copy of the bounce? Use my other email - [email protected]
Thom
The First Carpoke!
Has thanked: 140 times
Been thanked: 159 times
Excellent post @Darwin, this will be very helpful and inspirational for anyone attempting to install a standalone ECU - when it's done, there is no going back to the old Bosch Mo(t)ronic.
'90 944 turbo
Darwin
I get that a lot of people would prefer the original connector, but I did manage to find a suitable replacement for the oil level sending unit.
https://www.summitracing.com/parts/smp- ... HkQAvD_BwE
It isn’t pretty, and it isn’t OEM, but it fits perfectly. From what I found out, the original connector was a Mercedes part that is now NLA. Kroon is working on a replacement but it wasn’t available at the time (not sure if it is yet) so I had to find something as mine had disintegrated beyond serviceability.
