I’m looking to get a set of bumpers for my garage walls to prevent (my kids) from opening car doors into them. The walls are painted concrete. I’ve seen several options and was wondering if any of the Carpokes had a particular brand they might endorse as high quality.
Groits usually has decent stuff and these are inexpensive, but look a little like something from my toy construction set that I had as an 8 year old.
https://www.griotsgarage.com/product/wa ... gKRAPD_BwE
Suggestions welcome.
Garage wall guards to protect dooors
There is a place that advertises in the back of Panorama that sells them, which are meant to go on the doors; however, I bet you could use them on the wall as well with some adhesive: www.doorshield.com
__________________
Drive safe, but fast.
- Been thanked: 4025 times
If you're looking for expertise on padded walls, definitely check with @Crazy Eddie
I'd be inclined put some high-density foam in strategic locations on the wall.... Hot glue gun should do the trick on most walls...
