Blown gt3 engine
Marioignacio
I have a friend who supposedly suffered a blown engine due to an oil change and over fill.
Marioignacio
Has anyone had something similar occur?
toddinmd
Has thanked: 31 times
Been thanked: 59 times
Haven't had that happen and that would be an expensive lesson not to overfill. I have had my 991.2 GT3 throw the overfill message after I changed the oil. Oil level was fine after the change, but after a run, I had to take about 3/4 a cup of oil out. The car does throw the message on the dash if it's overfilled for the 2015-on cars.
Depending on the amount of overfill and how hard the engine was run, you can definitely damage the engine.
2018 991.2 GT3
2022 Taycan CT4
Has thanked: 4604 times
Been thanked: 2498 times
Marioignacio wrote: Thu Feb 16, 2023 12:45 pm I have a friend who supposedly suffered a blown engine due to an oil change and over fill.
Same answer as toddinmd.
Am I correct in assuming that your use of "supposedly" indicates that your friend is not 100% sure that an overfill is the cause of the blown motor?
Some specifics would probably help too - model, year, mileage, performance mods, how it's been maintained and by whom, what kind of driving at the moment the engine blew.
SignalY_GT3
Has thanked: 2 times
Been thanked: 5 times
Wow that is scary.
Dean
Easy to do. Have a 991.1 and the oil measurement is extremely quirky. Sometimes it works, often it doesn't. Read temp has to be 190 but have found that's no guarantee you'll get one. So when adding oil I do very little at a time. Bring back the dipstick
