The car has been doing this since buying it 16 years ago and instead of keeping sitting on this negligible issue I thought I would tackle it for good - am I the only one who can hear a subtle wind noise coming from the driver's door, that disappears when only very lightly sliding down the window?
Could it be the outer window rubber seal as it "seems" to lie against the window and provide a little better seal then?
Wind noise
- Been thanked: 4012 times
I can't say I've ever noticed that on my car, but I'm typically zoned in on interior rattles and engine noise.
Does it happen at any particular speed? I'd be inclined to put painters tape over suspect areas/seals to see if you can isolate exactly where it's coming from. (Then deal with whatever it is....)
On our other project, I injured me knee recently (MRI pending) and it's keeping me from getting out there and finishing it. Still high on my list, but I have to get off these crutches first...
- usury
- Has thanked: 100 times
- Been thanked: 93 times
You are not the only one. My 944 has done exactly that since I bought it in 1999 when the car was only 12 years old. It hasn't gotten any worse at least.Thom wrote: Sat Nov 05, 2022 11:37 am am I the only one who can hear a subtle wind noise coming from the driver's door, that disappears when only very lightly sliding down the window?
and Wrench Warrior
Seattle, Washington, USA
and Wrench Warrior
- Thom
- The First Carpoke!
- Has thanked: 138 times
- Been thanked: 153 times
Tom, sorry to hear about the injury. I hope it's not as bad as the crutches suggest. Take it easy and get well soon.
I suspect the issue may be caused by the outer seal. As the window is slightly moved down, it seems to pull the outer seal down and then perhaps closes a negligible gap that may be causing the noise.
Could the white plastic film inside the door actually cause any noise if it is not anymore completely stuck onto the door frame?
'90 944 turbo
Awaiting any MRI on the knee. Fingers crossed. I can't imagine the vapor barrier having the room or airflow to make enough noise to hear at speed. Does it sound like a piece of plastic flapping in the wind??Thom wrote: Tue Nov 08, 2022 9:57 am Tom, sorry to hear about the injury. I hope it's not as bad as the crutches suggest. Take it easy and get well soon.
- Thom
It really is only a relatively low and continuous wind noise coming from the driver's door, that I ended up noticing only after driving some other cars that drove quieter. It has never really bothered me that much but at this stage I would just like to get to the bottom of it. Getting old I suppose.
'90 944 turbo
FWIW I replaced all the rubber and guides on both doors years ago. Not an easy job getting all those seals and guides deep inside the door in their proper places. But the huge improvement in wind noise was replacing the OE flag mirrors with 968 models.
- Mr. Toasty
- Has thanked: 12 times
- Been thanked: 5 times
I’ve forgotten what it’s like to hear wind noise from the windows. I really need to install my door seals!
That lower seal does sit differently against the window depending on the window’s position, at least on my car. The window shifts outward very slightly as it reaches the top of its travel, and no adjustment of the guides and regulator makes that shift disappear. You could try rolling/bending the lower seal in a little (it’s metal inside), and maybe it’ll move just enough to fix the problem. It’s also worth checking the front corner by the mirror since the lower and upper seals meet there at a pretty tight angle
Member #944!
1987 944 S
1987 944 S (engine fire and part out)
2003 Subaru Outback LL Bean: not that exciting, but never fails
1987 944 S
