944/968 - LED Illumination for Clock or Temperature Display
hgryska
LCD display failures of the 944 clock or 968 temperature modules are accelerated by the heat generated from the light bulb. The power and generated heat of a LED is an order of magnitude lower and especially for the temperature module such a mod is useful as there are no replacement LCD displays available. Find attached the instructions to replace the bulb with an LED.
