4.0 Black Emblems
Post things for sale here!
Bob Z
Been thanked: 112 times
The new order has finally arrived - thanks to all for your patience. These are $30 each or a pair for $59. As a reminder, these are larger than the original order (about 1 1/8" high) so they will work well on the back of the, lower/front door corners, wing ends (GT4), etc. PM me if you are interested; however, I did not order as many this time. And I will include a template to help you line them up on whatever you want to put them on. There is a protective backing on the top surface, which I peeled off for the picture, and a covering on the back to protect the adhesive until one is ready to apply them. As a heads-up, be careful with the "dot" since it is small!
4_0 Emblem.JPG (1.99 MiB) Viewed 1207 times
__________________
Drive safe, but fast.
