Washing day, she really hadnt had a proper clean over the 2-3 years she been in various stages of being in parts.
Welcome 16 Valvers -- PICS needed!
I have an '87 S, in Alpinweiß with black, all original interior except for the radio.
73k miles, bought in October of 2025.
List of things I've repaired or replaced:
- Rebuilt the oil cooler
- New motor mounts
- Air oil separator seals
- Fuel injector O-rings
- Fuel sender seal
- Oil pressure sender
- Idle control valve
- Power steering pump
- Glove box arms
- Media console tray
- Hood pad
- Hatchback lock seal
- Hatchback seal
- Hatchback pin receiver
- Wiring for rear compartment light
- Re-finished the gauge reflector well and upgraded to LEDs
I just received a ton of parts to do a water pump and timing refresh, new throttle position sensor and vacuum lines.
- New motor mounts
- Fuel sender seal
- Glove box arms
- Hood pad
- Hatchback seal
- IMG_1076.jpg (3.77 MiB) Viewed 241 times
- IMG_1075.jpg (3.99 MiB) Viewed 241 times
- IMG_1078.jpg (3.53 MiB) Viewed 241 times
- IMG_1053.jpg (3.79 MiB) Viewed 241 times
- Has thanked: 4604 times
- Been thanked: 2498 times
@alsoicode
Your car appears pristine - great find! Congrats! I like that shade of white too - it's a bit warmer and nice to look at.
Also, a somewhat belated welcome to Carpokes!
This is true. I always short wider for more crop range. Although didnt crop for this upload. You are correc. BBS LMs 18'' I like the RS GtsLatitude48 wrote: Fri Jun 19, 2026 2:51 pmGreat lighting effects in that picture. It would be even greater if it was cropped to show more car and less concreteWheels look like BBS LM. I have similar 18" RS-GTs on my S2.
Absolutey that. I shoot wide for more crop scenarios when needed.blueline wrote: Fri Jun 19, 2026 3:00 pmRegarding a more generous crop, that was my first reaction too. But then I looked at it longer and realized that it was perfect the way it is - kind of a surreal look. It's a Jeff Zwart style image in many respects. Jeff would put a pic like that on the last page of Panorama!Latitude48 wrote: Fri Jun 19, 2026 2:51 pmGreat lighting effects in that picture. It would be even greater if it was cropped to show more car and less concreteWheels look like BBS LM. I have similar 18" RS-GTs on my S2.
I guess ideally, you'd use both versions - as-is as well as cropped.
