Spyder owners: Anyone bothered by the holes...
Tom: it must have been one of the first sets that I had to sand a bit to fit so if Scott says they fit perfectly then don't bother sending me ones that are smaller, and you can proceed with the metal ones.
__________________
Drive safe, but fast.
Spyder Scott
- Has thanked: 3 times
- Been thanked: 1 time
Yes, in black anodized aluminum.
- Been thanked: 4015 times
Hey Scott, sorry your cover warped.
p.s., some of the free stuff I make for people is subject to non-commercial licensing restrictions, so as a general rule, when I give away free parts, my intent is that they be used for personal, non-commercial use unless you check with me first....
Spyder Scott
Got it. I was trying to be proactive to come up with a better solution than plastic, since mine warped, and were basically unusable. I had never read prior to just recently that anyone was working on a metal version, which is clearly the best solution.
Thanks and no worries. I only heard about the warping a week or so ago, and so started working on an aluminum version right away.Spyder Scott wrote: Mon Sep 26, 2022 2:55 pm Got it. I was trying to be proactive to come up with a better solution than plastic, since mine warped, and were basically unusable. I had never read prior to just recently that anyone was working on a metal version, which is clearly the best solution.![]()
I was able to find a temporary fix for the warping but heating them with a hairdryer and gently bending them to where they are flat again, and I used a heavy ingot over the top when they were still hot to ensure they stayed that way. I suspect that the same thing will happen again, and maybe sooner, but at least they will work until we have a better option.
__________________
Thanks Bob! And the anodized aluminum versions are on the way! Most places cut a flat piece of anodized aluminum, which leaves the edges raw silver, so trying to work out the most efficient way to deal with that.Bob Z wrote: Wed Oct 05, 2022 7:10 pm I was able to find a temporary fix for the warping but heating them with a hairdryer and gently bending them to where they are flat again, and I used a heavy ingot over the top when they were still hot to ensure they stayed that way. I suspect that the same thing will happen again, and maybe sooner, but at least they will work until we have a better option.
Thanks Tom, you are the man! I am surprised they could not anodize the entire piece, edges and all, but I am sure we can figure something out. Personally, I am ok with painting the edges with a little flat black or satin paint, like Testors as can be found at most hobby or craft stores. Or as I did my current pair, I covered them with some Satin Black vinyl, which is pretty close to the shade of the surrounding area.Tom wrote: Wed Oct 05, 2022 7:35 pmThanks Bob! And the anodized aluminum versions are on the way! Most places cut a flat piece of anodized aluminum, which leaves the edges raw silver, so trying to work out the most efficient way to deal with that.Bob Z wrote: Wed Oct 05, 2022 7:10 pm I was able to find a temporary fix for the warping but heating them with a hairdryer and gently bending them to where they are flat again, and I used a heavy ingot over the top when they were still hot to ensure they stayed that way. I suspect that the same thing will happen again, and maybe sooner, but at least they will work until we have a better option.
__________________
For my own stuff, I typically run Sharpie around the edge and call it a day, but that only last for a while, and I'd prefer to offer a lifetime part.Bob Z wrote: Wed Oct 05, 2022 7:38 pmThanks Tom, you are the man! I am surprised they could not anodize the entire piece, edges and all, but I am sure we can figure something out. Personally, I am ok with painting the edges with a little flat black or satin paint, like Testors as can be found at most hobby or craft stores. Or as I did my current pair, I covered them with some Satin Black vinyl, which is pretty close to the shade of the surrounding area.Tom wrote: Wed Oct 05, 2022 7:35 pmThanks Bob! And the anodized aluminum versions are on the way! Most places cut a flat piece of anodized aluminum, which leaves the edges raw silver, so trying to work out the most efficient way to deal with that.Bob Z wrote: Wed Oct 05, 2022 7:10 pm I was able to find a temporary fix for the warping but heating them with a hairdryer and gently bending them to where they are flat again, and I used a heavy ingot over the top when they were still hot to ensure they stayed that way. I suspect that the same thing will happen again, and maybe sooner, but at least they will work until we have a better option.
