044 and AEM Fuel Pumps Screaming
Strange. I've had three 951's (over the past 30 years) here in Texas where 100+ days are normal and I've never had these fuel pump problems. Just wondering if it could be anything else. On a sadder note, I am once again Porsche-less, with money burning a hole in my pocket.
- Been thanked: 4007 times
It's definitely the pump making the noise. Exactly what is taking them out is still kind of a mystery. New parts on order and should be here soon.dme wrote: Tue Jun 03, 2025 4:43 pm Strange. I've had three 951's (over the past 30 years) here in Texas where 100+ days are normal and I've never had these fuel pump problems. Just wondering if it could be anything else. On a sadder note, I am once again Porsche-less, with money burning a hole in my pocket.
michaelmount123
- Has thanked: 26 times
- Been thanked: 179 times
Tom, is your pump rubber mounted?
Kind of... it was previously mounted in rubber anti-slip walkway material I wrapped around the pump. When I last changed it, I thought maybe that was trapping heat so I changed it to a rubberized plastic clamp cushion I 3D printed, shown below. I ordered a new factory 944 Turbo pump and rubber cover this time....
Morning Tom.
Just curious since you have been doing so many little electronic projects, have you thought about setting up a voltage and amperage monitor at your fuel pump? Might shed some light on what may be happening?
Tom wrote: Wed Jun 04, 2025 7:52 am
I did check voltage at the pump with a multimeter and it seemed fine, but while chasing this issue I did install new heavy gauge wires straight from the battery via a relay controlled by the original wires. Never logged voltage and current, but I could if throwing new stock parts at it doesn't fix it...
chrischrischris
- Has thanked: 4 times
- Been thanked: 33 times
My pump was screaming last year. I tried some super premium gas and that didn't help, and I changed to a new pump and the new one started screaming too. The issue turned out to be a bad FPR which resulted in elevated pressure that I guess the pump didn't like.
That's what I was wondering about. Heat just doesn't seem right considering all of us here in the desert southwest.chrischrischris wrote: Thu Jun 05, 2025 9:28 am My pump was screaming last year. I tried some super premium gas and that didn't help, and I changed to a new pump and the new one started screaming too. The issue turned out to be a bad FPR which resulted in elevated pressure that I guess the pump didn't like.
I run a relatively new 3 bar bosch FPR. I'd think my AFR's would be off if the pressure were off by enough to affect the pump, but is a theory I hadn't thought of, and checking it is free, so I'll check it for sure... Thanks!chrischrischris wrote: Thu Jun 05, 2025 9:28 am My pump was screaming last year. I tried some super premium gas and that didn't help, and I changed to a new pump and the new one started screaming too. The issue turned out to be a bad FPR which resulted in elevated pressure that I guess the pump didn't like.
p.s., suddenly wondering how well those FPR's hold up to e85...
