944 A/C Condenser Leak
Has thanked: 277 times
Been thanked: 274 times
The oil discussions are pretty settled. For conversions that don't include flushing, using the ester oil rather than Denso's recommended PAG, is purely a question of how much gelled sludge you can tolerate. In an expansion valve, it dramatically limits flow and system performance. On heat exchanger surfaces, it's an insulator and slows heat transfer. Not worth the risk in my casual experience. Using the correct oil is only slightly less convenient than using PAG, and that's only if you are installing a new compressor already filled with PAG. If you are buying a fresh bottle for your project (and you should...) anyway, grab the light-green synthetic polyolester and worry none about it.
For a longer period of years watching folks do their own 'conversions', more than a few owners complained about how the R-134a just didn't cool the cabin as well. It was pretty easy to see where the small details, like not replacing the oil in the system with the correct oil for the conversion, not changing changing ALL the o-rings, not using barrier hose, and not evacuating the system completely before charging, make the difference between ice-cubes air temps and the ~~50ºs they were seeing. Of course it's gotta be the refrigerant! Meanwhile, the system thrives on care and cleanliness, performing every step of the work, and in our cases we must get the charge levels exactly correct without relying on the sight glass.
Miss any of the steps, and at minimum, performance suffers. A few, like draining and replacing using the correct oil, are critical to both performance and system longevity. PAG and the old mineral oil used with R12 form a gel that restricts flow, plus the new oil that bound in the gel no longer lubricates the compressor, including wetting the mechanical seal on the drive end. The simple choice of ester over PAG as replacement eliminates that risk completely.
Installing a fresh Denso compressor in a flushed-clean system? Sure, the PAG they ship in the compressor is fine. Just drain it out completely, pour back in the exact amount the whole system requires, and you are good to go! For the rest of us mere DIY mortals converting our own cars, ester is the right choice.
In my limited experience with such things...
#51
Has thanked: 962 times
Thought I'd give a long-term update on the eBay condenser. It's been hot all week here -- into the 90s at times -- and I've had the 944 out to enjoy the sun. Very happy to report the a/c is blowing nice and cold still. This may be a record for me as I've not had to top off the refrigerant for two summers now! I haven't checked the actual temps from the vents, but it still feels icy cold to the touch, so I'm pretty happy with the eBay condenser and the system in general (knock on wood). :thumbup:
#52
Gaspowered
Has thanked: 320 times
Been thanked: 92 times
Based on your posts from last year, I bought the same condenser directly from the company last October (saved a bit on local sales tax by talking to them directly).
So far, same as you, I'm enjoying cold a/c for the first time in a while.
Thanks @Tom
Brian
'88 944 Turbo S / Silber Rosa
#53
nick_968
I'm considering a retrofit on my 968 (3.0 8v turbo) but will have to use 944 turbo hard lines I think, due to the routing of these being more suited compared to the 968 where they would run to close to or clash with the turbo and/ or downpipes.
My question is, for those of you who have done the r134a switch, and the reference in Dr. Bobs post above re using barrier hose, have you upgraded the rubber end sections of your metal hard lines to barrier hose? I assume the full rubber lines that run from the compressor to the condenser are an easier switch to barrier hose versions?
Also would new lines from Porsche also come with barrier hose these days?
#54
