Page 5 of 5
Re: 951 Resurrection - after 7 years of storage
Posted: Fri Jul 10, 2026 9:01 am
by Meine44
sletcher wrote: Fri Jul 10, 2026 8:00 am Hardline PS clamp is 10 x 15 clamp pn 99951111602
I think any 15mm diameter clamp would work, but hope that helps. I order nuts, bolts and clamps from Belmetric.com , they have p clamps there too. I think you need an m6 mounting hole.
Yes, that is helpful, thank you! I will add this to the list of items to source from the local hardware store.
Sometimes I get stuck searching the PET parts catalog and forget that I have the ability to remove small parts like this and bring them into a brick-and-mortar store for comparing :oops:
Posted: Fri Jul 10, 2026 9:49 am
Meine44 wrote: Thu Jul 09, 2026 8:54 am Also, I would appreciate any help identifying two small pieces that I need to replace:
-The clip that holds the rear interior trim piece to the body of the car. Two are broken and one is missing. This clip holds the interior trim / leather side panel to the inside of the trunk.
-There is a hard-line clamp near the oil pressure sender that has disintegrated - the rubber is thrashed.
You can get those cushion clamps at a local hardware store, or amazon, though the ones Porsche sells are higher quality by a country mile (thicker rubber, thicker metal)... That panel clips are available, but you may need to re-secure them in the panels (JB Weld, etc.)... I 'think' your picture shows this style...
Posted: Fri Jul 10, 2026 11:13 am
by Meine44
Tom wrote: Fri Jul 10, 2026 9:49 am
Tom, I think you are right! PET shows 27 of P/N 823-867-299 are used in the car. Interestingly they are only shown for the interior door panel but there is a good chance that is the part I am looking for.
Thank you!
