Spyder owners: Anyone bothered by the holes...
Since I am using velcro to secure mine removing them is easy since I just need to press down on one side, which raises the other side allowing me to pull it out. The velcro makes it flexible but in no way does it cause it to come out on its own - I have speed tested them (120+) and I bet one could not go fast enough to lose them!
__________________
Drive safe, but fast.
The issue with resin is the potential for the part to shrink or expand during the post-processing. I’m pretty sure I could make it work l, but alas I don’t have a car to test fit.
2023 982 Spyder
2006 997.1 Carrera S
2006 Tundra
2006 Tundra
Tom will send you the file and it has been perfected by a couple of us - the size is perfect on my car so if you make it the same size it should be perfect as well.OakenGoby wrote: Mon Sep 12, 2022 7:01 am The issue with resin is the potential for the part to shrink or expand during the post-processing. I’m pretty sure I could make it work l, but alas I don’t have a car to test fit.
__________________
Spyder Scott
- Has thanked: 3 times
- Been thanked: 1 time
I tried that process but didn’t work as well as I anticipated. I used Velcro tabs versus cut pieces of Velcro. Maybe your approach provides more flex? I still feel having the small notch guarantees easy removal. The downside is needing a small tool to put in the notch to initiate removal.
Spyder Scott
Velcro tabs I used (low profile):
- Pigs-In-Space
- Has thanked: 37 times
- Been thanked: 12 times
Bob,
Has anybody reproduced these for sale yet? I just read through this string and it looks like private parties with 3D printers only???
Thanks,
Jim
Thanks,
Jim
2026 911 Targa 4S - Black Olive
2025 Cayenne GTS - Shiraz Red
2024 Honda Ridgeline Black Edition - White
2022 718 Spyder 6MT - Gentian Blue
2020 Cayenne Turbo - Chalk
2019 911 Turbo S - Agate Grey
It appears you did not read this thread after all! Tom made some but as I said mine are warping so we are discussing an option such as metal - standby to this thread for updates.Pigs-In-Space wrote: Sat Sep 24, 2022 6:54 am Bob,
Thanks,
Jim
__________________
- Pigs-In-Space
Meant for sale and available now. So in short your answer is NO.
Sorry. Wow. A little cranky this morning are we?
Just messing with you, sorry if I came off as being rude. But this is something that I dreamed up a while back and with the help of others, mostly Tom since he is the lead, so we need to get a better option so it will take time, which is documented in this thread.Pigs-In-Space wrote: Sat Sep 24, 2022 7:12 am Meant for sale and available now. So in short your answer is NO.
__________________
