Page 5 of 9
Re: The project I'm currently working on, 71 911
Posted: Tue Apr 11, 2023 7:08 am
Thanks! That explains it. Lighting when the picture is taken plays a role too, so it helps to know that it's still Viper Green. It's looking good!
Posted: Sun Jun 11, 2023 5:46 am
by Carmagic
Here is a little update for the 911:
Assembled the tail lights. They are all LEDs.
Test fitted the rear bumper.
Made new brake lines, and installed them.
Also installed the brake calipers.
I started on the electrical system.
I had to take a break on the wiring and started to install the sound mats.
Back to the wiring.
Most of the harnesses are new and home made.
Engelbert
Posted: Sun Jun 11, 2023 7:00 am
Everything is so precise Englebert - amazing work! Thanks again for letting us see this transition.
Posted: Sat Jun 24, 2023 2:16 pm
by Carmagic
I started a few pieces for the interior.
Made a new knee pad and test fitted the dash trim.
Refinished the dash trim with the same vinyl I covered the knee pad.
Finish installed.
Engelbert
Posted: Sat Jun 24, 2023 5:44 pm
Wow, you are really a man of many talents. Upholstery too! Looks fantastic!
Posted: Wed Sep 06, 2023 3:04 pm
by Carmagic
Sorry for not posting any update work I did since the last post. I was quite busy the last few weeks.
Here are a few pictures. I will soon post about the work I did since the last post above.
Engelbert
Posted: Wed Sep 06, 2023 3:12 pm
Carmagic wrote: Wed Sep 06, 2023 3:04 pm Sorry for not posting any update work I did since the last post. I was quite busy the last few weeks.
Engelbert
Wow. Just wow... Was wondering how all was progressing. Now we know.
Thanks again for continuing to share the progression of your project with us. Looking forward to your usual details and pictures. :thumbup:
Posted: Wed Sep 06, 2023 4:07 pm
Looks amazing! Fantastic job. Can't wait to see the work details! Will you keep it and drive it or sell it and start a new project?
Posted: Fri Sep 22, 2023 2:35 pm
by Carmagic
OK, here are some updates and pictures on the work I did.
Finished the tank, I upgraded to SC/Carrera gas tank.
Fitting the oil lines and second oil cooler.
The oil thermostat had one damaged fitting connection.
I got a repair sleeve and installed it.
I had the rear wheels widened by 1" at the inside. I started to refinish them. First polishing the outer lip.
Masking the polished lip and blasting the rest of the wheels.
Back to the interior. Got the dash pad back from recovering.
And got it installed. I had to tweak it a bit, but it came out OK after that.
Installed the engine sound pad, and made a new electrical panel.
Made and installed all new fuel lines.
Got all the dash wire sorted and install my gauges.
The battery mount and the electrical panel and wiring is coming together.
The headlights are installed.
The deck lid with custom grill and integrated 3rd brake light is installed.
I totally forgot about the fresh air system. So it has to done now.
The fan was coming apart, so I needed a new one.
Here it is after refinishing and ready to get installed.
It's time to install the engine.
More with the next post.
Engelbert
Posted: Fri Sep 22, 2023 4:05 pm
Carmagic wrote: Fri Sep 22, 2023 2:35 pm OK, here are some updates and pictures on the work I did.
Engelbert
Awesome Englebert, simply awesome. As always, thank you for sharing this with us.
