A/C Compressor & Condenser Replacement
Has thanked: 935 times
Been thanked: 4006 times
samaritrey wrote: Thu May 29, 2025 7:11 am Great guide I wish I had found it before I did my AC refresh on my 951!
I bought a roll of rubber adhesive strips 2 inch wide by 1/8 inch thick to wrap around the Drier and it worked great.
Center vent temp of 39F with 27oz of R134. 85F outside with about 243% Humidity so it was feeling nice inside even with my Saratoga roof.
Sadly, the weld broke on the condenser holding the metal line to the assembly when I did the orings.
Will have to replace it next time the system needs work.
A little TIG tack might fix that? Or get the aluminum parallel flow one on eBay - it will make your system even colder. :)
#31
