Sam_Flat6 wrote: Tue Jan 07, 2025 2:58 pm
I’m looking for track experienced drivers to weigh in. I just bought a Cayman GT4.0 with LWBS, PDK, and PASM (20mm), primarily so I can drive to and from tracks on for the next few years. I also own a Boxster 25 use it occasionally for some touring purposes (similar car but different purpose). I’m new to Porsche platform but skilled with plenty of track days behind me (currently drive a track built S2000). My goal is to setup the GTS4.0 for HPDE track days and yet retain some street drivability. Unlike the S2000, I understand the Cayman has some limitations on alignment and setup in OEM form. I’ve researched the net and reached out to several performance shops/retailers to get opinions on the following. All of them offer contradictory opinions. Thought I would get knowledgeable answers from this forum and learn how best to approach my goals and mistakes to avoid given my lack of experience with Porsche platform. In the end I want to walk into my local performance race shop armed with good information to compare against their recommendations.
After break-in and some seat time in stock form, I would like to modify stock components for improved safety, braking, and handling while enjoying the car off the track. The intent is to improve safety and performance while on track and not build a GT4/RS replica. I’ve run a non-aero track setup for years so it will a “sleeper” type build that slides under the radar to the eyes of many. Here the list I have so far.
Safety: Half-cage/roll bar with 6pt harness, SS brake lines, seat angle adjuster for proper helmet position
Brakes: wheels studs w/ track pads and rotors
Wheels: Apex 18”
Tires: 200 tread wear in 245/285 f/r specs
Desired alignment: -2.5/-2.0 with 8.5 caster and some rear toe
Suspension: front LCAs/camber plates, rear toe arms, strut tower steel plates
Exhaust: headers, OAP, back box setup w/ tune
I’m keeping OEM shocks and springs for now. May move to Tractive shock body and DSC tune if needed while maintaining the PASM function. Please reply with your thoughts on the following.
1. LCAs or Camber plates or both? Tarret, Elephant Racing or Rennline experience?
2. Strut tower reinforcement needed? Cup plates or Emotion Engineering strut brace?
3. Recommendations of a brake pad compound friendly for HPDE and drive to and from track days.
4. Are stiffer springs a must out of the box?
5. Should I consider tractive/DSC sooner than later?
6. Quality SS brake line recommendations?
7. CMS/BBI/Cantrell half-cage/roll bar experience?
8. Anything else to consider with this platform?
Thank you for your knowledge and responses - PMs welcome as well.
