Plastic T5 Nuts
danmartinic
Has thanked: 23 times
Been thanked: 39 times
Hmm.. car is an '88 built in August '87
Yes your cover looks different.. my right side hole goes onto a horizontal stud as you can see by the wall anchor lol
I can tell you that the holes do not reach the studs unless you really push up on the harness... and that harness is very, very stiff!!
I almost couldn't get it back on and I am surprised the little nuts hold with all that back tension from the harness
#31
Been thanked: 4011 times
Right, the harness is like concrete. I can only imagine what horror is would be if I cracked a wire off in there.... It would need to move up at least an inch, probably two. It's been fine for about 30 years this way, so I'm starting to think I should leave well enough alone.
#32
danmartinic
I was more concerned with leaving the harness exposed: my left foot would constantly rub on it to the point that some of the tape was rubbing off!
Darn Italian dress shoes and their long pointy tips lol
#33
Darwin
Has thanked: 116 times
Been thanked: 74 times
Tom wrote: Fri Feb 04, 2022 6:07 pm Right, the harness is like concrete. I can only imagine what horror is would be if I cracked a wire off in there.... It would need to move up at least an inch, probably two. It's been fine for about 30 years this way, so I'm starting to think I should leave well enough alone.
Oh no! I hope you didn't get the wrong one :( My harness has sagged over the years since I removed my cover so it does serve a purpose. I will definitely be reinstalling mine, but that harness is so thick right there!
2012 VW Tiguan - Kinda stock
#34
Darwin wrote: Sat Feb 05, 2022 10:29 am
No, no, I'm 99% sure you sent me the right one for my '86. Thanks again. It matches PET, and Dan's car uses a different part number. Whether I'll ever get it on is an entirely different issue, but I do think it's the right one. :)
#35
danmartinic
Unbolt the fuse box under the hood and lift the harness up... install the cover... then reinstall the fuse box
I pulled the fuse box up to get at the clutch master rod... sure, the harness is stiff, but I hardly think the wires are so brittle that you can't maneuver them
How many times have we handled that stiff harness at the ECU/DME?
#36
danmartinic wrote: Sun Feb 06, 2022 5:50 am Unbolt the fuse box under the hood and lift the harness up... install the cover... then reinstall the fuse box
I'll take another swing at it soon. I did try pulling up the fuse box, but wimped out on pulling hard enough to do any good.
#37
