Got some left over high vac stuff from work.
Will report when I get stuff back together.
ArnnWorx
- Has thanked: 961 times
- Been thanked: 4160 times
Wrong thread?gruhsy wrote: Thu Feb 29, 2024 1:43 pm Got some left over high vac stuff from work.
- NCGermerican
- Has thanked: 155 times
- Been thanked: 106 times
Unless that is grease for the throttle body o-rings and needle bearings?
Tom wrote: Thu Feb 29, 2024 6:41 pmgruhsy wrote: Thu Feb 29, 2024 1:43 pm Got some left over high vac stuff from work.
Throttle body o-rings and sealing up the bearings.
One of my coworkers was going to throw out the tube as the job was done.
Wrong thread?
Ah, sorry, got it!
Itneedseverything
I would buy a kit as well for my 1985/2 NA 944. Any time frame when it might be available? Thanks
Knock on wood, I might be freeing up a bit this week. Let me see if I can pull a couple basic kits together. Stay tuned.Itneedseverything wrote: Mon Jul 01, 2024 12:29 pm I would buy a kit as well for my 1985/2 NA 944. Any time frame when it might be available? Thanks
Itneedseverything
Thanks soo much. I’ve been through every system on this build and those darn special fasteners and o rings are near impossible to find. And without them all the other work to get the system tight again won’t be the same if we can’t rebuild the TB. You will be a life saver! Thanks again!!
- Jotronic
- Has thanked: 59 times
- Been thanked: 33 times
Jotronic wrote: Thu Jun 20, 2024 6:26 pm Sooooo, what's the latest on this @Tom ? Were you able to get anything started? My TB is toast and I need a kit and NO ONE sells one:(
Update: I don't need a kit any longer as I needed a TB sooner rather than later and ordered a refurbished unit from S&P Engines in the UK. 159 british pounds, not bad.
