Picture Request
Has thanked: 4457 times
Been thanked: 2418 times
Larry C wrote: Tue Dec 27, 2022 11:38 am When I had my Audi RS3, I asked the dealer to change the rear emblem. They had a template and changed the emblem perfectly in 5 minutes. There was no charge. I’m sure the Porsche dealerships have similar templates.
Our local Porsche dealer has templates - a bunch of them. I even know where they keep 'em stored.
Unlike Leader's experience with his Porsche dealer, the techs here are extraordinarily conscientious, at least all the ones I deal with. Maybe that is out of the ordinary regarding cosmetic type work but I wouldn't think Porsche certified techs would be sloppy about anything related to their work. They have to be good on the cosmetic side of things, especially considering all of the various trim panels, body parts, dashboards, seats, add-ons, etc. inside and outside the vehicles that have to be removed to fix pretty much anything on later gen Porsches.
But, as with pretty much everything in our lives, it boils down to the individual(s) doing whatever it is that needs to be done. No one is guaranteed immunity from shoddy, untrained, unskilled work or care no matter the field. However, steps can be taken to limit risk.
Der Tgr
Been thanked: 6 times
As usual, I'm late to the part, but I didn't see one of these yet:
Greg
2022 718 Spyder, White
2018 Macan S, Volcano Gray
2014 Cayman S, White
Gone, but not forgotten:
2015 Carrera S, Black
#32
Been thanked: 667 times
How difficult is it to remove an existing badge? I’m considering removing my existing ‘718 Cayman GTS’ and adding a GTS emblem.
Bill in Bama
Has thanked: 16 times
Been thanked: 155 times
Use dental floss. Get the strong kind like Glide. After the emblem comes off heat the area gently with a hair dryer, keep it moving, and some sort of glue remover that's approved for painted surfaces. You can even heat the emblem before flossing it, just don't get it too hot.
'84 944, my first Porsche DBM
#34
Larry C wrote: Mon Mar 13, 2023 8:34 pm How difficult is it to remove an existing badge? I’m considering removing my existing ‘718 Cayman GTS’ and adding a GTS emblem.
PPF guys do it easily using very thin monofilament as I've been told. Getting the replacement positioned correctly is the next challenge after finding the one you want. Aftermarket maybe or used? New from dealer is crazy expensive. Attaching a used one properly is another hurdle without the adhesive that comes on the new ones. :)
Tom & Tim thread: viewtopic.php?p=13866&hilit=emblem+adhesive#p13866
Adhesive product:
https://www.amazon.com/dp/B000PEWDJW/?c ... romSmile=1
chester
Has thanked: 35 times
Been thanked: 14 times
Mid-engine aficionado from Austin, Texas
#36
718-4Me
Has thanked: 23 times
Been thanked: 26 times
My '17 Cayman S, black is beautiful!
gzxfia
Has thanked: 28 times
Been thanked: 20 times
Didn't want to start a new thread as it's a related topic but... can someone help me out by measuring the distance from the bottom of the "PORSCHE" trim to the top of the model designation badge (in the center)? I think the PPF company installed mine too low.
I did see a picture from another forum that showed 1 and 5/8" below the PORSCHE trim but mines currently at 3" below which is way more than 1" off. Comparing my before/after pictures it appears about the same albeit slightly off but not more than 1" off. It also could be the angle of the bumper and picture where I can't get quite right.
So I'm hoping to double check with someone here if possible. Thanks!
#38
Pachanga718
Has thanked: 236 times
Been thanked: 127 times
Mine from when it was at the dealership - has not changed
#39
gzxfia
Pachanga718 wrote: Mon Sep 16, 2024 9:31 am Mine from when it was at the dealership - has not changed
Thank you, from that angle definitely looks higher than mine.
Do you mind measuring the distance between bottom of the "PORSCHE" black trim piece and top of the "C" if it's convenient for you?
Also is the bottom tip of the "y" in Cayman sitting flat to the panel?
My "y" is hanging over the curve with a little bit of lift, so another sign to me that it's placed too low.
#40
