ALEXtheGREAT
Tom wrote: Wed Jun 28, 2023 6:27 pm
ALEXtheGREAT wrote: Wed Jun 28, 2023 5:59 pm Quick question regarding the tensioning tool!
I successfully used it this past weekend but had a question of the "feel" of the belt. After using the tool and setting the timing belt tension to the "N" spec since my belt is new, I went to do the good old twist/ deflection test just to confirm. I noticed the belt only twists about 45 degrees and doesn't have much deflection. I had the cam gear set counter clockwise a tooth and a half during the tensioning. I'm just paranoid that the belt is too tight and it may eventually destroy the water pump bearing lol.
Is the 45 degrees of twist normal tension that should be felt when using the factory Porsche tool and/ or the carpokes tensioning tool? Am I being paranoid? Is the tension okay?
Thanks!
If you printed the tool and used a reasonably accurate torque wrench set to 7 ft. lbs., so that the wrench hit 7 just as the N pointed lined up with the chrome belt rail, then you should be right around the spec for a new belt. I've never been a fan of the twist method because it's so subjective and dependent on relative hand strength, etc. If you ask an NFL linemen and Peewee Herman to both tighten the belt until they can twist it 90 degrees, you're going to get two very different results. Even among typical shade-tree mechanics, how hard are you supposed to twist and how do you know how much is too little or too much. Also, there is no twist-spec for a new belt as far as I know -- so if 90 degrees is where people ultimately want to run the belt, then it must be something less than 90 when the belt is new? The factory new-belt spec of 4.0 is noticeably tighter than the used-belt spec of 2.7, yet that doesn't seem to come up when people talk about the twist method. Bottom line, I'd rely on the tool, properly used, over a subjective test with no verifiable reference points.
I used my snap on 3/8 drive torque wrench with it set to 7 ft lbs reading. I agree with the twist method concerns, there's no way you can twist the belt the same way twice. I'm most likely being super paranoid here.
Professionally I've done quite a few timing belts so I'm probably just being really paranoid. The car is still on jack stands so I imagine after 500-1000km of driving when I go to do the re tension, the timing belt itself will become a bit more loose.
#201
nein44
This is fantastic -- just got all of my parts in to do my first belt service (water pump & front seals as well), and look forward to using this tool. Thanks!
#202
last lemming
first post for the 3d file!!
#203
Can944Guy
Hoping to download the 3D tensioning print.
#204
monacobianco
Thank you so much for this! Is there also a version for the balance shaft belt? My car is making a lot of belt noise atm and also a wierd grinding/squeeking noise at idle sometimes...
Thanks again :)
#205
monacobianco wrote: Mon Jul 10, 2023 2:03 pm Thank you so much for this! Is there also a version for the balance shaft belt? My car is making a lot of belt noise atm and also a wierd grinding/squeeking noise at idle sometimes...
Thanks again :)
Thanks. I have not yet done one for the balance shafts, but it is on my list! Grinding/squeaking sounds like more than belt tension though...?
#206
lukegoode8
Been thanked: 5 times
Any update on anyone finding a fix/alternative for the 944s 16v engine? Made the mistake of printing the regular tensioner before noticing it wouldn't fit.
Also has anyone come across any good videos or directions for the common maintenance (belts, water pump, etc.) for the 16v? I try looking but obviously it's a bit harder than finding 8v videos.
#207
lukegoode8 wrote: Mon Jul 10, 2023 5:43 pm Any update on anyone finding a fix/alternative for the 944s 16v engine? Made the mistake of printing the regular tensioner before noticing it wouldn't fit.
Did you try it and confirm it does not fit? I originally thought it would be for the 8 valves only, but then started second-guessing myself after looking at pictures of 16 valve motors....?
#208
zoom944t
Has thanked: 2 times
Tom, are you still printing these out for folks? I don't have access to a 3D printer. for a 87 Turbo. I'm using race Kevlar belts (if that matters). Thanks again for all your help on this site.
#209
zoom944t wrote: Tue Jul 11, 2023 1:16 pm Tom, are you still printing these out for folks? I don't have access to a 3D printer. for a 87 Turbo. I'm using race Kevlar belts (if that matters). Thanks again for all your help on this site.
I have done a few, but am currently out of the reinforcement screws and the short M10 bolt for the main drive. I can print the plastic part for you and insert the brass thread insert for the cost of parts and shipping, if that works. PM me if interested....
#210
