Re: 86 Turbo fuel pump wires both show ground.
Posted: Sat Nov 01, 2025 7:58 pm
It's been a little time since I've had time to do some more testing but tonight I was able to use a MAC NOID light to verify I'm getting power to the injectors, I'm getting spark using an inline tester, and I'm getting fuel pressure at what I'm calling the "test port" at the front of the fuel rail.
It does not even attempt to give any indication of starting. With fuel, spark, and air I should at least get a sputtering of an attempt to start.
Seeing all three of these I would think the DME is possibly working. Any idea where I should look next? I've seen a suggestion of maybe the injectors being clogged but all of them?
Tom wrote: Sun Oct 05, 2025 4:59 pmDid you just put new connectors on the old wires or install patch harnesses like LR and 944 online sell?Richey wrote: Sun Oct 05, 2025 4:54 pm I got around to changing the connectors and still crank no start. I also replaced the DME relay and that didn't help either. I also know my reference sensor and speed sensors are good as they test fine with a multi meter and they put out voltage in the correct range when turning over the starter.
At this point what else is there to test/replace? The car cranks over freely but there is never even the slightest attempt at starting. It might be the DME but I really have not found any good suggestions on how to test the DME other than just swap it out against another one. I don't have a second DME to test with so I'm kind of at a dead in.
Any suggestions on how to test the DME short of just buying another one?
If you want to send me your DME, I'll toss it in my car and see if it fires up...![]()
