Road map to 300 HP...
- fasterfaster
- Has thanked: 172 times
- Been thanked: 28 times
Storch now has a plug n play MAF kit for the 951 that looks pretty clean and well-developed if you can't track down one of the domestic kits.
Marc
88.5 951 M030 Red on Black
The 3” exhaust will do nothing. Just have a shop cut out the stock cat and weld a new sport one. Spool up will improve.motoken wrote: Fri Jun 12, 2026 1:42 pm Thanks again for all of the helpful information.
I wanted to share this link to some more helpful info i found on the web:
https://jmgporsche.co.uk/item/178-tunin ... rboparttwo
Curious if you all agree with the articles info?
Right now i am leaning toward the following:
- Keep my stock turbo.
- Swap to a three inch cat delete exhaust (LR with Borla).
- Dual port waste gate (LR or Tial)
- LR Max Chip
- Manual boost controller (LR)
- 3.0 FPR (LR)
Might add a gauge cluster for the boost controller and a boost gauge.
i think I should be able to put this together for about $2k.
Thoughts?
Thanks in advance.
Ken
Does LR chip support increased fuel pressure? If not then you don’t need the fbr.
***edit. Looks like Max chip does need an a 3 bar fpr. I have one available that I’m no longer using. PM me if interested.
If you're going down the route of manual boost control and chips, I suggest having some monitoring in place.
https://www.zeitronix.com/Products/zt2/zt2.shtml
This will also allow you to log to a laptop which is smart to review later as monitoring gauges for very log is hard while driving. There are a ton of sensors you can add to this for a good picture on things.
chrischrischris
- Has thanked: 7 times
- Been thanked: 45 times
I'd recommend getting your fuel injectors serviced (cleaned). Not expensive and good to do after 40 yrs of flowing fuel.
