With my lift I think it needs only 2 inches of height to unlock.
I will test this evening or tomorrow
And we have lift off
- Been thanked: 4085 times
Yes, to unlock you just need to go up a smidge on mine too. What I meant was that the lock positions are 6 inches apart, so you can't assume you'll be able to set the ramps to exactly the height you want, like 51" to just clear the top of the 944 -- you're options may be 50" or 56" or 60" etc.gruhsy wrote: Sun Feb 20, 2022 2:39 pm With my lift I think it needs only 2 inches of height to unlock.
Ah gotcha. Very valid point with lock positions
Tom wrote: Sun Feb 20, 2022 2:54 pmYes, to unlock you just need to go up a smidge on mine too. What I meant was that the lock positions are 6 inches apart, so you can't assume you'll be able to set the ramps to exactly the height you want, like 51" to just clear the top of the 944 -- you're options may be 50" or 56" or 60" etc.gruhsy wrote: Sun Feb 20, 2022 2:39 pm With my lift I think it needs only 2 inches of height to unlock.
