Tarett, Elephant Racing, or Rennline Camber Plates?
Amigo54
Been thanked: 13 times
good article here on this subject. from BRRacing in Los Gatos California
https://www.brrperformance.com/porsche- ... pgrade-it/
#21
J-Dub
Has thanked: 663 times
Been thanked: 574 times
Great article, lots of good information.
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
#22
Has thanked: 4525 times
Been thanked: 2453 times
J-Dub wrote: Fri Dec 08, 2023 5:01 pm Great article, lots of good information.
I skimmed through it earlier today - it's good. Very thorough and detailed.
3MOS
blueline wrote: Tue Aug 29, 2023 6:11 pm I went with Tarett Engineering's camber plates & rear toe-links as you already know and I am very pleased with them. They are a good company to deal with too. J-Dub and Danial also went with Tarett and they're both pleased as far as I know. The Tarett got the nod from a couple of pro racers too.
I stepped down to 19" x 9" and 19" x 11" wheels (the Apex forged SM10RS) for track use which allows 265 ft and 295 rear. On the GT4 I could go to 305 in the rear but the well clearance is tight and therefore questionable. Plus, Hoosiers are available for me in 265 and 295 but not 305.
Agreed. I'm also planning to use Tarett's front camber plates and rear toe links. They'll be combined with rear camber plates (Alekshop) to run 265/305 on 19x9 and 19x11 Apex wheels with the new Hoosier TA Pros. Should all work well, but will circle back if there are any issues.
#24
3MOS wrote: Thu Oct 03, 2024 7:11 pm
Would definitely appreciate feedback as you gather additional data and info. Thanks!
rbpeirce
Been thanked: 15 times
blueline wrote: Tue Aug 29, 2023 6:11 pm I stepped down to 19" x 9" and 19" x 11" wheels (the Apex forged SM10RS) for track use which allows 265 ft and 295 rear. On the GT4 I could go to 305 in the rear but the well clearance is tight and therefore questionable.
I'm running stock 20" wheels and I regularly use 305s on the rear. I haven't had any problems. How are the 19" wheels different?
2016 Audi A7
2021 Porsche GT4/PDK
#26
rbpeirce wrote: Fri Oct 04, 2024 5:33 am
It's not that 305s won't work but rather that there are additional considerations that make 295s better for my use.
I'm using Tarett Engineering suspension upgrades which allow considerably more negative camber than can be achieved with stock 718 suspension components. At -2.75 all around, the clearance is tight and 305/30 at the rear will stand a very good chance of not mixing well with hard track driving. IE: hitting the inside inner wells.
Also, OEM rear 20" tires for a GT4 are 30s whereas the 19" MPSC2 available are 35s. With 35s, the circumference, sidewall height and overall diameter is higher, (respectively by approx 5%, 17%, 5% - per online tire size calculators). With the 295/35 I'm pretty much already at the limit for clearance.
There is further discussion of others' suspension/wheel/tire setups for Cayman GT4/GTS track use earlier in this thread and also within a couple of other topics at Carpokes.
GT4 alignment screenshot 2023-11-30 (Small).png (366.93 KiB) Viewed 826 times
Has thanked: 527 times
Been thanked: 270 times
Interesting discussion gentlemen, and I don't have a Cayman, just an old 951, but the focus is the point. There have been similar points/questions on my platform and after reading many articles on handling, alignment can make or break a cars personality. Thank you for sharing.
Has thanked: 3386 times
Been thanked: 957 times
Using Tarett front camber plates along with their toe link arm in the rear and am running 255s up front in both 18s and 19s. Running 295/30/18 Hoosiers in the rear with the 18 inch Apex wheels ( forged ) and 285 RE71RSs in the rear with the 19s ( flow formed Apex wheels ). I just got in a set of GT3 A-Arms from Rennline and will get a set of studs from Apex this coming week ( I like that they do a 75mm stud ) and will look at pushing the limits of my alignment close to -3 up front and around -2 to -2.5 in the rear. Just corded a rear Hoosier so looking to get these items done , but once completed I should be able to run a 265 up front and a 305 in the rear if desired. Good info from everyone. Special thanks to blueline and J-Dub for their ideas when I got started on getting my alignment adjusted to better track specs.
#29
3MOS
blueline wrote: Thu Oct 03, 2024 7:15 pm
Noted - should have feedback next week, and hopefully (wait list permitting) track usage feedback by the end of the month.
#30
