Page 3 of 9
Re: The project I'm currently working on, 71 911
Posted: Wed Feb 01, 2023 2:34 pm
by Carmagic
Posted: Thu Feb 02, 2023 2:04 pm
by W5Hans
Hi,
I find this so much fun to follow super nice that you let us watch along and good luck.
Posted: Tue Feb 07, 2023 9:32 am
by Ix_
Thank you for sharing this with us. I hope you keep the car the same color (Conda/Signal?).
Can you share any history of how you acquired the car and when? Just curious.
Posted: Wed Feb 08, 2023 12:41 pm
by Carmagic
Posted: Thu Feb 09, 2023 2:49 pm
by Carmagic
I started fitting the rear brake system for the 71 911 project.
Here are some pictures. I use 964 calipers. The rear calipers were modified to fit the rear mounting of the 911 banana arms.
I'm using 930 rear rotors.
I had to modify the dust shield because of the larger diameter of the 930 rotors.
After the brakes for the rear of the 71 911 is all fitted, the calipers were blasted and ready for coating and rebuild.
Here are all pistons cleaned and ready.
I made some plugs to plug the cylinder holes, and used some old brake line ends to plug the line and bleeder holes.
I tried something new and used a heat dissipating ceramic coating.
Brake line complete and ready to bend and install.
I got new SS bolts which holds the guide plates for the brake pads in place, which had to be modified a bit to make space for the thicker rotors.
The bleed valves restored.
Here are the completed calipers.
Engelbert
Posted: Thu Feb 09, 2023 5:39 pm
by DMRK
Totally awesome! You are very skilled, great thread. This kind of work has always scared me. Now I feel inspired by seeing what you have done. Thank you for that. Someday maybe when I run out of projects I will try to build an AWD 914 with a twin turbo W12. OK, probably not but you are truly inspiring.
Posted: Fri Feb 17, 2023 10:05 am
by Carmagic
Another small piece of the puzzle, restoring the pedal system.
Back then when I built the car for AX, I just put new brass bushing in and put it back together so it will function. Now is the time to clean it up a bit.
I did some minor repair and grit blasted all the pieces.
I coated the larger pieces with Cerakote black velvet, and zinc plated the small stuff.
There is still some pitting to see in the housing, but I did not want to grind it out, since it would just thin the material.
I'm using Carrera Bilstein front struts for the 71, since they have 3.5" spacing for the caliper mount. I also added the bump steer supports.
Original the struts are green like a John Deer Tractor, but I like to have them Bilstein Yellow. Since I still had some of the correct color powder, I powder coated them yellow.
I also finished some of the other suspension pieces.
Engelbert
Posted: Fri Feb 17, 2023 11:02 am
It all looks so new!! Awesome!
Ok, I'm going barn hunting to find a hidden P hulk for your magic. (Yeah - I picked a section of your un on purpose.) Anyway, I'd hate to see you bored once your current projects are finished, hence the barn search. Hahaha.
Seriously, fantastic work Englebert - it's great for us to be able to see so much of what you do. Thanks for sharing it!
Posted: Mon Feb 20, 2023 12:11 pm
by Carmagic
A few more things to check off the list.
The front hubs are finished, they are ready for new bearings, etc.
Also finished the spring plates.
Another little project was to restore the front and rear hood locks.
All disassembled and ready to clean up.
Grit blasted and ready for plating.
Finish plated and ready for assembly
All assembled and ready.
Since I will use the fuse box of the later model car, I also started to sort out the wire harness between the dash and fuse box.
Most of the wires I will replace. They are old and some of them are stiff and the insulation is getting brittle.
I made new left and right outer harness for the headlight/blinker. I also added a wire for the DRL included in the LED headlights. Also some of the other wire setups already complete.
Here the inside harness from the fuse box to the headlight/blinker.
Old.
Pretty ugly
The plugs at right is the only piece I will reuse.
Only left to put on new sleeving.
There was only one relay next to the old fuse box for the horn. With the new fuse box I will have space for many relays. I will use the original relay mounts, so I will have relays at the fuse box for horn, low beam, high beam, Oil cooler fan, and whatever else is needed.
Engelbert
Posted: Mon Feb 20, 2023 12:21 pm
Love your posts!! You are an inspiration to get out in the garage as I sit here and type.
Can I ask what powder coating oven you have and/or if you made your own? I have an old one from Harbor Freight -- the orange oven long since discontinued -- and it's great for most stuff, but would love to have the extra room I see in your pictures!!
