Not now
Install
Hide
How to do it?
DJOTron wrote: Fri Aug 29, 2025 1:50 pm
Final Update: I ended up carefully tightening the gap between the top and bottom pins (pin 17), reinstalled the cluster, and bingo - the trip reset works! @Tom - Huge thank you for your guidance in testing the different possibilities. I’m glad the issue is resolved, and hopefully this thread will help someone else troubleshoot their own trip reset woes.
Awesome, so glad you were able to pinpoint it. It's not a circuit I'd focused on much in the past, so it was time well spent not only to fix your car but also to get the basics out there for posterity. Hope to see you around Carpokes and be sure to tell your friends about us.
