- Has thanked: 4604 times
- Been thanked: 2498 times
@Brob132 and @BKP944
Welcome to Carpokes! Glad you found the site - looking forward to having you both as part of the forum.
@liamflynn183
Likewise Liam - welcome to Carpokes!
- Has thanked: 961 times
- Been thanked: 4160 times
How old is that water pump? Do you know for sure your car does not have the rail? Porsche has called for the new style pump with rail on all 944 and 924S motors since its TBS in 1987, as the only approved replacement. There is an increased chance of timing belt failure without the rail. Timing belt tools aside, you'd be better off with the new style pump. Without the rail, I guess you could still use the tool and either mark or visualize where the rail should be, but that may introduce some inaccuracies if not done carefully.HasseN wrote: Fri May 26, 2023 6:36 am Hi, I have a 924 S from 1986 with no WATER PUMP GUIDE RAIL, can I still use this belt tensioner?
