Page 16 of 23
Re: 944S2 16V Turbo Build
Posted: Mon Aug 18, 2025 5:59 am
by Bergerac
Yeah I picked mine up for under 600euro on special :D
Posted: Mon Aug 18, 2025 11:43 am
by BasHenneman
Bergerac wrote: Mon Aug 18, 2025 5:59 am Yeah I picked mine up for under 600euro on special :D
You sneaky man! Thats a steal!
Posted: Tue Aug 19, 2025 4:41 pm
by Bergerac
Prekom sports hardess bushes and M030 rear sway bar have arrived. I assume these are the same as what Elephant Racing sells, from what I've read Prekom was the OEM.
Posted: Tue Aug 19, 2025 9:40 pm
by Bergerac
It's alive!
Posted: Mon Aug 25, 2025 6:48 am
by Bergerac
Ok, Im a bit stumped on this one, we cranked the engine over until we got just under 2bar oil pressure. Started it and it jumped straight to 4.5bar with a lot of lifter noise, ran it for a couple of minutes to see if they pumped up but no change so we stopped.
Ended up pulling the cam cover off and theres no oil in the head at all, confirmed the check valve is in and the vertical oil passage from the block is clear.
What next? Fill the head oil passages, reinstall the check valve and try again?
I cant think of anything else it could be apart from the main oil passage being blocked and I would have thought we would have excessive oil pressure if that was the case.
Posted: Mon Aug 25, 2025 6:51 am
by BasHenneman
Bergerac wrote: Mon Aug 25, 2025 6:48 am Ok, Im a bit stumped on this one, we cranked the engine over until we got just under 2bar oil pressure. Started it and it jumped straight to 4.5bar with a lot of lifter noise, ran it for a couple of minutes to see if they pumped up but no change so we stopped.
Start the engine with the valve cover removed to see if you have oil coming out of the passage.
Remove the check valve to make sure you get oil to the top.
Then check the check-valve; mine was rusted solid after having been in the engine for a long time.. New ones are pricey though.....
Posted: Mon Aug 25, 2025 7:02 am
by Bergerac
BasHenneman wrote: Mon Aug 25, 2025 6:51 am
Thanks Bas, Ill give that a go tomorrow, we did pump oil in through the filter housing before we turned it over so I would have thought at least some would have made it to the head but maybe there wasnt enough pressure.
I do have a spare check valve, I bought it by accident not realising my head already had one. I dont think it was seized though, it came out pretty easily.
Posted: Mon Aug 25, 2025 7:07 am
by BasHenneman
Bergerac wrote: Mon Aug 25, 2025 7:02 am
Well, getting the valve out was the easy part to be honest, but once you take a look at the actual valve, you'll see what I mean.
I didnt take a picture of the stuck valve, but did find a picture of doing an oil pressure test on my S2 turbo (I sent it to you through Facebook Messenger).
If you start long enough, you should get up to 4.5 bar of oil pressure, maybe even 5.
Posted: Mon Aug 25, 2025 7:29 am
by Bergerac
Yeah the spring looked fine and the ball moved freely. Got 4.5bar oil pressure started the car but the head is bone dry.
Posted: Mon Aug 25, 2025 7:43 pm
by Bergerac
So we got oil with the valve out, put it back in no oil.
Turns out the check valve seat hadn't been fully pressed in from the factory so it was partially blocking the oil passages and not allowing the ball to move enough.
