Page 14 of 14
Re: 944 Odometer Gears
Posted: Sat Dec 13, 2025 2:12 am
by spad944
che differenza a il numero di denti ??
Posted: Sat Dec 13, 2025 7:26 am
Translation of spad944's post:
"What difference does the number of teeth make?"
All the way from Italy it appears! Nice. Welcome to Carpokes!
Posted: Sat Dec 13, 2025 8:03 am
blueline wrote: Sat Dec 13, 2025 7:26 am Translation of spad944's post:
The gears are designed to work together to produce the right calibration. A gear with too many or two few teeth might bind and/or will produce inaccurate measurements. Your replacement odometer gear needs to have the same number of teeth as the original, unless you change the whole gear set.
Posted: Sat Jan 17, 2026 2:05 am
by custard
Mine has already been replaced with a metal one, however it seems the second gear in line is missing a tooth, and that's causing it to bind up every so often. Don't suppose anyone has modelled that one? If not, next time I have the cluster apart, I'll give it a go.
Posted: Wed Mar 11, 2026 8:57 am
by Leaky944
Posting just to say I will be downloading these. Thanks
Posted: Sun Mar 22, 2026 12:45 am
by Dee
Thanks!
Posted: Tue Mar 24, 2026 11:29 am
by dnor
Thank you!
Posted: Sat May 02, 2026 1:57 pm
by miferr
Looking forward to getting the pdf and the gear-print file. Thank You!!
