944 Odometer Gears
spad944
che differenza a il numero di denti ??
#131
Has thanked: 4471 times
Been thanked: 2429 times
Translation of spad944's post:
"What difference does the number of teeth make?"
All the way from Italy it appears! Nice. Welcome to Carpokes!
Has thanked: 941 times
Been thanked: 4028 times
blueline wrote: Sat Dec 13, 2025 7:26 am Translation of spad944's post:
The gears are designed to work together to produce the right calibration. A gear with too many or two few teeth might bind and/or will produce inaccurate measurements. Your replacement odometer gear needs to have the same number of teeth as the original, unless you change the whole gear set.
#133
custard
Mine has already been replaced with a metal one, however it seems the second gear in line is missing a tooth, and that's causing it to bind up every so often. Don't suppose anyone has modelled that one? If not, next time I have the cluster apart, I'll give it a go.
1987 Porsche 944 NA - Alicante, Spain
#134
Leaky944
Posting just to say I will be downloading these. Thanks
#135
Dee
Thanks!
#136
dnor
Thank you!
#137
miferr
Looking forward to getting the pdf and the gear-print file. Thank You!!
#138
