gzxfia
Has thanked: 28 times
Been thanked: 21 times
J-Dub wrote: Sun Mar 01, 2026 10:29 am Oil change
Front brake pads after I completed a set on track last weekend, a 6 hour drive home on backing plate to rotor :wtf:
Swapped my track wheels back to my street wheels.
A good once over looking for loose bolts.
Are these stock the OEM pagids like GT4/Spyder? How many miles and track days?
It's about time for me to change pads so I'm doing a bit of research.
Stock pagids on our Spyder worked very well on 4 track days, 2 AX, and canyon/street (they're seemingly 4 years old), so leaning towards replacing with same rather than more aggressive DS1.11 and better. Changing the pads seem like a PITA to me, unless I upgrade to caliper/line studs :think:
#1271
J-Dub
Has thanked: 662 times
Been thanked: 573 times
These are aftermarket pads, Ferodo 3.12 that i tried to get the last bit out of and took it too far. I am not sure how many track days, some times I do 4 days a month.
The pads are a cinch to change. I personally think the talk about needing studs to be over-hyped. If you are not using an impact to bolt the calipers on you are fine.
gzxfia wrote: Fri Mar 20, 2026 11:03 am Are these stock the OEM pagids like GT4/Spyder? How many miles and track days?
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
#1272
J-Dub
Yesterday had the paint protection film replaced in the areas around the rear wheels which is where it gets roughed up on the track. They also did a quick buff and freshen the ceramic coating.
1957 VW Beetle
2004 VW R32
#1273
gzxfia
J-Dub wrote: Fri Mar 20, 2026 7:13 pm These are aftermarket pads, Ferodo 3.12 that i tried to get the last bit out of and took it too far. I am not sure how many track days, some times I do 4 days a month.
Did you use the 3.12 for dual duty (street + track)?
I really should just unlazy myself and swap in for the 4-6 track days a year :lol:
J-Dub wrote: Sat Mar 21, 2026 1:46 pm Yesterday had the paint protection film replaced in the areas around the rear wheels which is where it gets roughed up on the track. They also did a quick buff and freshen the ceramic coating.
I too need to replace some PPF (full front and rockers) after track days. Dreading it a little bit since the front was done by previous owner and I saw some paint chips that's underneath the PPF; last thing I want to deal with is paint ripping along with PPF :sick:
#1274
Has thanked: 4518 times
Been thanked: 2451 times
Looking good!
I did the same regarding PPF 2-years ago - it was time.
Recent work on the GT4 at PoN, including twice annual brake fluid flush/bleed (still using Motul RBF 660), full PDK/diff service - all fluid replaced again (I've done this twice since new), replaced all 8 rear axle boot clamps including new seals, hardware and the like, installed Motorsports strut reinforcement plates, new Schroth 6-pt harness sets (current had expired and PCA is now checking), new starter and more.
The car has also been detailed - finally. (It sat track-dirty all winter.)
J-Dub
Yep, I put on the 3.12s and never looked back. They are really good on the street, great cold bite actually.
On previous cars I have ran track pads that are terrible on the street, no bite when cold, super dusty and incredibly noisy. These are not like that at all.
gzxfia wrote: Sat Mar 21, 2026 2:53 pm
1957 VW Beetle
2004 VW R32
#1277
J-Dub
All excellent, except the starter. I did not expect that. Have you been having starter issues leading up to this?
blueline wrote: Sun Mar 22, 2026 10:34 am Recent work on the GT4 at PoN, including twice annual brake fluid flush/bleed (still using Motul RBF 660), full PDK/diff service - all fluid replaced again (I've done this twice since new), replaced all 8 rear axle boot clamps including new seals, hardware and the like, installed Motorsports strut reinforcement plates, new Schroth 6-pt harness sets (current had expired and PCA is now checking), new starter and more.
1957 VW Beetle
2004 VW R32
#1278
J-Dub wrote: Sun Mar 22, 2026 1:54 pm All excellent, except the starter. I did not expect that. Have you been having starter issues leading up to this?
No issues whatsoever. Zilch. Starter was perfect as far as I knew. (Had been on track a day or so prior and all was well there too.)
As it turned out, the GT4 was sitting in the service lane last November after I drove it in for its annual. When the porter went to move it - nada. Wouldn't even come out of Park, so it couldn't even be rolled. :wtf:
Starter failure is not necessarily a common affliction for 718s but it has happened to others, so it was not unfamiliar to the techs. I'm glad it happened at the dealership and not elsewhere. I was lucky. Without a pair of dollies it would have had to have been dragged on and back off a rollback otherwise. That's a bit nightmarish.
Mfibiandriver
Has thanked: 47 times
Been thanked: 39 times
Just finished up one month road trip in 2024 Cayman S - West Coast to Yorktown, Va and back - destinations inspired by watching Ken Burns' documentary "American Revolution". And by signing up for two, back-to-back, two-day driving courses at Barber Motorsports in Birmingham. Variable weather with 91 degrees and snow, both within 18 hours in Charlottesville! The Cayman is a wonderful road companion!
#1280
