Page 13 of 13
Re: Shaftless Throttle bodies
Posted: Wed May 10, 2023 12:44 pm
by gruhsy
chris white wrote: Wed May 10, 2023 10:15 am
never glass bead a cylinder head....I did a 'bench head' that I use for mock ups and 2 years later it still spits up a glass bead every now and then! Soda blasting is best for any parts that are internally exposed to oil/intake air/coolant.
Hope my post was not misleading as I would never recommend blasting a cylinder head
Block off plates just to show how over the top I will go to keep debris out of intake and exhaust rather than stuffing a rag into a port.
Canβt really block of the valves on a head when removed.
The turbo mount was blocked off with a fitting on one piece and aluminum plates like you see on my intake. Sealed with sealant as well.
I am trying to convince work to get a vapor blaster which would be ideal and does not warp thin parts.
Posted: Wed May 10, 2023 12:50 pm
by gruhsy
So the rotor screws really suck to remove when they are sitting in a car for 20 years.
Left hand drill bit.
Irwin extractor
Proto extractor
Heat gun
Cold spray
Most important is endless profanity directed at the part until broken piece extracted. PM me if you want to know what words work best.
The more offending the better as it scares the part into submission
Posted: Wed May 10, 2023 1:01 pm
gruhsy wrote: Wed May 10, 2023 12:50 pm
Irwin extractor
Proto extractor
Heat gun
Cold spray
Great post! Gave me a big smile for the day.
Posted: Wed May 10, 2023 1:05 pm
by chris white
its important to learn to swear in German, other wise the parts will ignore you.
Posted: Wed May 10, 2023 1:14 pm
chris white wrote: Wed May 10, 2023 1:05 pm
I found a great list but even though the English translations are sanitized I'd probably still have to ban myself.
Then again, the German versions look pretty harmless.....
