Sweet! I have an older 718 version (2021) of your car. Black on black on black - "murdered out" is the term someone told me it was called. Lol
- Has thanked: 4604 times
- Been thanked: 2498 times
I never miss an opportunity to mention Tom's marvelous solutions for no-drill rear plate mounting for 718s, 991/992s and Cayennes. They are incredible, high-quality, foolproof designs that not only mean no drilled holes whatsoever but also help promote Carpokes.Sam_Flat6 wrote: Sat Aug 23, 2025 12:56 pm I did something similar except replaced rivnuts by drilling holes and installing automotive grade plastic inserts on all my cars.
app.php/carpokes-store
viewtopic.php?t=1733&start=1120#p48030
Although I like this an as option, I’m not a big fan on adhesion mounted items on paint except for PPF.blueline wrote: Sat Aug 23, 2025 2:24 pmI never miss an opportunity to mention Tom's marvelous solutions for no-drill rear plate mounting for 718s, 991/992s and Cayennes. They are incredible, high-quality, foolproof designs that not only mean no drilled holes whatsoever but also help promote Carpokes.Sam_Flat6 wrote: Sat Aug 23, 2025 12:56 pm I did something similar except replaced rivnuts by drilling holes and installing automotive grade plastic inserts on all my cars.
‘25 Cayman GTS 4.0 | ‘22 Miata RF Club
‘21 Boxster 25th Anniversary | ‘06 S2000
IG: @9n3affliction
IG: @9n3affliction
I get that and understand the concerns. Your solution is also a very good one.Sam_Flat6 wrote: Sat Aug 23, 2025 2:51 pmAlthough I like this an as option, I’m not a big fan on adhesion mounted items on paint except for PPF.blueline wrote: Sat Aug 23, 2025 2:24 pmI never miss an opportunity to mention Tom's marvelous solutions for no-drill rear plate mounting for 718s, 991/992s and Cayennes. They are incredible, high-quality, foolproof designs that not only mean no drilled holes whatsoever but also help promote Carpokes.Sam_Flat6 wrote: Sat Aug 23, 2025 12:56 pm I did something similar except replaced rivnuts by drilling holes and installing automotive grade plastic inserts on all my cars.
As a note for others who might have concerns, the ones from Carpokes are not a problem for any modern paint or PPF. The adhesive on the mounts is basically the same as used by Porsche for things such as rear emblems and the like which can be removed without damaging paint. No permanent holes to the rear bumper area is a plus for some too.
The mounts for the new gen (2024 and later) Cayennes are not adhesion mounted as Porsche finally wised up and put two secure (but oddly positioned) mount points on them. (They don't fit license plates from any country whose plates I've seen but at least they provide a great place for a properly designed mount.)
I have no idea why Porsche does not provide some kind of basic, adaptable mount point for all their vehicles.
- Larry C
- Has thanked: 595 times
- Been thanked: 672 times
My first and favorite mod.blueline wrote: Sat Aug 23, 2025 3:36 pmI get that and understand the concerns. Your solution is also a very good one.Sam_Flat6 wrote: Sat Aug 23, 2025 2:51 pmAlthough I like this an as option, I’m not a big fan on adhesion mounted items on paint except for PPF.blueline wrote: Sat Aug 23, 2025 2:24 pm
- JodehFoster
- Has thanked: 57 times
- Been thanked: 89 times
getting back on the track for a DE weekend in a couple weeks...time for fresh meat. I had numbers made to match my seat belts. Because people do that, right?
I also bought the GT4 shifter recently, but waiting for the knob I ordered to arrive before I install. Seems a fairly simple install (famous last words), and a post for another time.
2018 718C S 6MT
2021 Macan GTS
2021 Macan GTS
- Robertsmania
- Has thanked: 50 times
- Been thanked: 62 times
I love that as a number solution! Are window numbers legal for SCCA, PCA, etc?
2025 982/718 Cayman GTS 4.0
2025 982/718 Cayman
2010 987.2 Cayman S (220k miles!)
2000 BMW M-Roadster
1998 BMW Z3
1974 Alfa Romeo Spider (1st car as a teenager, still own it!)
2025 982/718 Cayman
2000 BMW M-Roadster
1998 BMW Z3
- JodehFoster
Thanks!
I'm not sure about SCCA, but I've used them with both MKEPCA (RA) & NORPCA (Mid-OH) events with no problem. I have a rectangle I slap on the hood too.
Bought these through Firestorm Graphix...I asked them to do the custom backgrounds for me (they ended up using my car on their site). They are very happy to help out.
https://firestormgraphix.com/catalogsea ... orsche+981
- 532A2818.jpg (6.95 MiB) Viewed 1849 times
2018 718C S 6MT
2021 Macan GTS
2021 Macan GTS
- Pachanga718
- Has thanked: 236 times
- Been thanked: 129 times
They look great - much better than blue painter's tape!JodehFoster wrote: Mon Sep 08, 2025 11:46 am Thanks!
