Page 11 of 13
Re: Shaftless Throttle bodies
Posted: Tue May 02, 2023 10:48 am
by gruhsy
I am re-building this engine for Erik.
Not sure if it’s going to be the 86 block or the original 89 block yet.
I am going to try this shop and I think he can fix it.
http://www.custombalancing.com/enginebalancing.html
Every rotating part will be delivered to him for balancing as it’s local to us.
Engine only had about 15000km/ 9000 miles
A shop in California did the crank work originally back in 2001 or 2002. Never seen one modded like it.
As far as crank replacement if needed I will trade Erik one of my 2.5L cranks and money for a 3.0L crank he has.
Tom wrote: Tue May 02, 2023 9:09 am Yikes, I guess I'll spring for the $2 oil pick-up seal for my next motor. :shock: Think that crank will polish out or would you have it machined/hardened? I have one from a 2.7 motor (78.9mm) you can have, but I can only imagine what they'd charge to ship a 65lb crank to you....almost certainly more than it's worth.
Posted: Wed May 03, 2023 1:27 pm
by gruhsy
Little bit cleaner and nicer looking.
Posted: Wed May 03, 2023 1:49 pm
Wow, looks great. What process did you use to get such a silvery finish?
Posted: Wed May 03, 2023 6:11 pm
by gruhsy
Tom wrote: Wed May 03, 2023 1:49 pm Wow, looks great. What process did you use to get such a silvery finish?
Bead blasted then light hand sand with 320.
Will hit it with 600 later
Posted: Thu May 04, 2023 5:30 am
by chris white
Try a drill mounted wire brush - it makes for a nice shine and it also smooths the surface so it doesn't trap dirt as well as the stock finish. Also very easy to touch up later!
Posted: Thu May 04, 2023 6:44 am
by gruhsy
chris white wrote: Thu May 04, 2023 5:30 am Try a drill mounted wire brush - it makes for a nice shine and it also smooths the surface so it doesn't trap dirt as well as the stock finish. Also very easy to touch up later!
I will potentially do that. I used a brass brush on my balance shaft covers and it gives it a slight gold color.
I would love to find an oil shedding clear coating as well.
After cleaning 7 blocks so far I want to come up with something that makes the job easier.
I want to buy a steam pressure washer so badly. Quite a few models to choose from and I like the 155C / 311F range ones the best.
They also have separate soap pump not the crappy siphon type. These models are still made in Germany I believe.
https://www.kaercher.com/int/profession ... 19270.html
I used one of my first turbo in 1994 to clean the engine and it was phenomenal. Nothing works better.
Posted: Thu May 04, 2023 9:38 am
by chris white
I usually have the block / head soda blasted as part of a build. that does a great job cleaning but leaves a surface that really traps oil/grease/dirt.
Try a steel wheel brush - I really like the finish it leaves on the alusil block - kind of shiny and smooth and seems to shed oil easily.
I also pressure wash the blocks / heads after any machining. Not much fun in winter!
Posted: Sat May 06, 2023 2:55 pm
by gruhsy
And more bad work
No Loctite on the crank girdle.
Posted: Sat May 06, 2023 2:57 pm
by gruhsy
Anyone familiar with this crankshaft work approach?
Posted: Sat May 06, 2023 4:13 pm
Butter-knife-edge crank?
