Here are the 2 source scad files that I used to produce the stl files using OpenSCAD. Please feel free to use and modify as desired. The font "911 Porscha" needs to be installed on your PC and can be found by searching for "911 Porscha font"markagsmith5 wrote: Mon Feb 06, 2023 4:23 am I have produced some stl files (944) based on this concept using OpenSCAD. Fairly easy to create this way.
The font for the "turbo" bit is not quite correct, as I don't believe it is actually based on a font. So I just picked a font that was similar. The point is that it shows a mixture of fonts.
Text x Flip Porsche 911!
markagsmith5
- Has thanked: 9 times
- Been thanked: 30 times
1987 944 Turbo
2024 BYD Seal Premium
