Re: Cooling Fans won’t shut off while running
Posted: Fri Jun 19, 2026 12:57 pm
Thanks Tom! This all makes sense. I have been verifying that the fans are on by cruising around my neighborhood and stopping to check. Agree they are hard to hear!
I pulled the radiator and I am attempting to fix the bunk Thermo fan switch threads. On top of the thread issue, the gasket that is held in with the tabs on the side of the rad started leaking
not the first time I’ve had to do that. I have also tried to source a 71c thermostat but none of the usual 944 vendors have them so I orders a Mahle behr 80c to see if it’s more accurate. The wahler’s have been inconsistent with accurate opening temp the last 4 or so times I’ve ordered them.
Working on the leaks will update once I have one and will try no thermostat if the issue persists.
