Re: Batwing hardware kit
Posted: Tue Apr 28, 2026 12:10 pm
Haven’t got there yet
https://carpokes.com/
Have a picture of the new design?chrischrischris wrote: Wed Apr 29, 2026 1:51 am Later versions of the batwing were improved with the addition of three finger-like projections integrated into the rear edge which attach to the engine tray, replacing that assortment of rivets, screws, speed nuts, and brackets.
Rather than use the OEM parts, a better solution would use a piece of aluminum or a 3D print to update the early batwing to the newer (better) design.
Tom wrote: Wed Apr 29, 2026 4:26 pmHave a picture of the new design?chrischrischris wrote: Wed Apr 29, 2026 1:51 am Later versions of the batwing were improved with the addition of three finger-like projections integrated into the rear edge which attach to the engine tray, replacing that assortment of rivets, screws, speed nuts, and brackets.
Shoulder washers are also used to fasten the lower sill black plastic trim. The Porsche pieces are very overpriced. Plastic would be a good material to use here as they will not corrode like the metal ones.whalenlg wrote: Wed Apr 29, 2026 9:35 pm For what it’s worth, I bought these on Amazon to put my Batwing on:
Maier USA Shoulder Washers 8MM -... https://www.amazon.com/dp/B074MJ2HKQ?re ... b_ap_share
They were much cheaper than the own ones. I also just found similar metric speed nuts at my local ace and a mixture of 6mm machine screws (Philips) and a couple of 6mm hex bolts.
Fyi - those ones are smaller - 6mm instead of 8mm. Metal ones are also on Amazon.chrischrischris wrote: Thu Apr 30, 2026 1:42 amShoulder washers are also used to fasten the lower sill black plastic trim. The Porsche pieces are very overpriced. Plastic would be a good material to use here as they will not corrode like the metal ones.whalenlg wrote: Wed Apr 29, 2026 9:35 pm For what it’s worth, I bought these on Amazon to put my Batwing on:
