Re: Wheel Alignment
Posted: Tue Oct 21, 2025 6:32 am
Im getting weird vibes about this shop, just sayin, you may want to take it elsewhere.
https://carpokes.com/
I am as well. It's a shame because they are one of the few euro indy shops in the area that can/will work on 944's. Even though I do most of my own work, there are just some things I need a shop to do (mount/balance tires and alignments).walfreyydo wrote: Tue Oct 21, 2025 6:32 am Im getting weird vibes about this shop, just sayin, you may want to take it elsewhere.
Measure the height from the ground to the bottom of the fender lip at the top of the arch, for both the front and rear. That should give you an indication. I think my car is stock and the height is 24.875 to 25 inches, consistent front and back. There is a recommended method in the Porsche shop manual and when I did the measurements and calculation, I came up with the front = 1.1”, rear=0.75”. I had not further researched those numbers to see if they were stock, though.NCGermerican wrote: Tue Oct 21, 2025 5:38 amIt's funny you asked that. To my knowledge, it's the stock ride height. The previous 2 owners of the car, back to around 2002 (from the records I have) were....at the age where I doubt they lowered the car - and there are no records of it. They look like stock springs to me. The only upgrades are the koni shocks front and rear.walfreyydo wrote: Tue Oct 21, 2025 5:01 am Is your car lowered? (An otherwise stock ride height car, should not need camber plates as the OEM eccentric bolt on the shock should allow enough adjustment). However, if its lowered, this makes sense (although I would expect the rear camber to also run negative, which is curious to me)
Front caster and toe appears to be the biggest adjustment they made. The rear was already in spec before the alignment. Again, likely the centering pin wasn't installed during front toe surgery adjustment. Basically when you adjust the tie rod, the steering wheel will move to compensate unless its locked down.
However, the shop told me the car WAS lowered. I told them it wasn't but they kept saying it was. It "looks" lowered because I have a larger diameter wheel/tire combo, plus the offset of the wheels puts them flush with the fenders. So it does "look" lower, but I'm 99.9% positive it's stock springs in the front.
