DSC Tuner Frustration
Has thanked: 4466 times
Been thanked: 2426 times
Unfortunately, I was also thinking that an issue with the device itself may be the cause of the problem, especially since there is significant communication going on between your PC and the DSC. There are only so many other possibilities that can be checked off before coming to that conclusion.
Is your DSC still under warranty? (Three years I think?) Even if not, I'd ask them if they'd troubleshoot the controller and get it up to specs if you send it to them. No idea what they'd charge but I'd think it would be reasonable. (Well, it should be anyway.)
Has thanked: 941 times
Been thanked: 4028 times
Have you tried a different USB cable? I learned to my great frustration that some are made to deliver power only...
Throttlesteer
Has thanked: 15 times
Been thanked: 37 times
Tom wrote: Thu Jun 12, 2025 1:38 pm Have you tried a different USB cable? I learned to my great frustration that some are made to deliver power only...
I just tried this, as I too have learned the hard way. But, alas, same result.
Throttlesteer
Good news! I finally figured it out. It required downloading the driver again, but making sure it was moved within the application folder itself. For whatever reason, launching the standard executable didn't do this. Simply downloading the driver didn't get it to the correct location either.
Thanks everyone for all of the educated guesses. The Carpokes community is a special bunch.
Great that you figured it out. And also very good to know what was done to get things corrected and connected! :thumbup:
ReidMcT
Has thanked: 142 times
Been thanked: 190 times
I notice the software is labeled 9x1. But it also apparently is compatible with 9x2 cars?
ReidMcT
The Hills, Texas
'21 Cayman T M6
'17 Boxster S PDK
Throttlesteer wrote: Thu Jun 12, 2025 3:10 pm Good news! I finally figured it out. It required downloading the driver again, but making sure it was moved within the application folder itself. For whatever reason, launching the standard executable didn't do this. Simply downloading the driver didn't get it to the correct location either.
That's great, congrats. Brochure saying no installation needed was probably written by the marketing dept, while the software guys were screaming yeah but, but, but... :lol:
Throttlesteer
ReidMcT wrote: Mon Jun 16, 2025 5:36 am I notice the software is labeled 9x1. But it also apparently is compatible with 9x2 cars?
Yes, but you have to order the correct unit. The map/tuning will work fine
