Ok -
Took the advice here and cleaned everything up and redid my rear main and balance shaft oil leaks. Hope that problem is now solved!
Here Is my question - what is the LEAST I can get away with to just start the engine to check these leaks have stopped? This is a turbo car. Can I run it for a minute or two with no crossover pipe? I believe running with no toque tube will not be an issue,
Lower bal shaft cover
- Drscottsmith
- Has thanked: 3 times
- Been thanked: 15 times
