Hi all, thanks for all the comments!
I thought I'd report back should someone else go through the same process...
So after running the smoke machine through different connection points, I ended up finding a few leaks. However, I am not sure if some leaks are considered normal or if the system should really be 100% leak free when doing these tests.
Here are some examples:
1) The smallest port on the jboot is leaking. It has the original squeeze clamp - it is either the clamp or the joint of the hose entering the port that is leaking slightly. I would like to replace the hose and clamp but cant seem to find the hose part number. Can I use a regular screw type clamp versus the squeeze clamp here?
2) The intercooler tube has a hose connected on the left side. The other end of that hose connects to a hard line if I recall correctlty, again using one of those squeeze clamps. There is a leak at the clamp...I will replace the clamp but wonder if this is normal when doing a smoke test?
3) Throttle body - there is a leak at the spring on the right hand side. The smoke seems to leak at the joint of the spring. I have no idea if this is fixable or normal... thoughts?
4) There was air coming out of my idle stabilizer valve at the two small openings in the metal body. Is this ok? One hose connecting to it has a small leak at the joint - again possibly the clamp.
5) one hose going to the cycling valve was split - I replaced that, but the cycling valve cap still shows smoke around it
It might be worth nothing - the issue I am trying to resolve on my car is that I need to keep giving it gas on a cold start until it warms up or the engine shuts off. If I don't give any gas on cold start up, the car will seem to "catch" for just a split second and shut off. Tom and others provided some guidance on testing and so far I have ruled out my air flow meter (I did the tests and also swapped with a known working one), DME temp sensor is new, DME temp sensor wiring has a short that was repaired, new FPR, new check valve, new fuel filter, new air filter, TPS tested fine, cleaned out my throttle body, new spark plugs....
For those of you interested - here is the link to the other post:
viewtopic.php?p=28428#p28428
I am wondering if I have a vacuum leak, but the car starts fine once it is warm...maybe a tad rough
Another symptom I have is a smell of gas coming from the rear of the car when it is parked. Lastly, I did also notice a frayed connector going to my idle stabilizer, but the wires don't seem to be shorting (however I will fix it).
My thinking is:
1) Resolve the vacuum leaks....
2) Can my fuel system be losing pressure which is causing the cold start issue? If yes, what can I check here? Fuel pump?
Thanks!
