Cruise Control (Tempostat) schematic
icb
Has thanked: 59 times
Been thanked: 54 times
icb wrote: Fri Mar 22, 2024 10:33 pm Is anyone else having or has had the issue where you set the speed and the car instantly picks up 5-10 MPH? This behavior only started after I replaced the last two original 2.2 µF/60V electrolytic caps (one of them had been leaking). I had replaced the other electrolytics previously and the speed control was perfect after that repair. Then it stopped working again, that's when I did these two, and that's when the speed increase started happening.
Here's a brief update on this part of the thread:
My speed increase was due to the cable having a wee bit too much slack in it. I should have checked this first, but I had removed and re-adjusted the cable many other times before, and hadn't noticed any difference in the speed control behavior, so I had thought the system wasn't sensitive to the cable adjustment.
Just prior to replacing the last two original 2.2 µF/60V electrolytic caps (a brief period where the speed control was not working), I had been chasing an idle problem, and to ensure the speed control cable wasn't affecting the idle speed/throttle, I had loosened off the adjuster a fair bit, leaving 5-8mm of slack . Last night, I saw something in an old 911 post somewhere about removing all the cable slack, and just to see what would happen, I re-adjusted the cable to leave about 2 mm of free play. Now the speed control engagement is totally seamless and perfect.
I hope this info might save someone from the PITA of unnecessarily removing the controller under similar circumstances in the future.
I still plan to draw up the controller schematic (actually there are at least two, maybe more versions) and post it here at some point, because we really do need it.
Ian Borg
1988 Porsche 944S
