718 Life: A 718 on Pucks
lukesward
Has thanked: 40 times
Been thanked: 251 times
Depends on the clearance depth inside the hole. I'm guessing it would be better to just start with a new luck and glue that shape to a new puck rather than on top of the pipe. I'll see if I can source some more pucks.
alavigne
Been thanked: 46 times
lukesward wrote: Tue Mar 12, 2024 7:43 pm Depends on the clearance depth inside the hole. I'm guessing it would be better to just start with a new luck and glue that shape to a new puck rather than on top of the pipe. I'll see if I can source some more pucks.
But it needs to be at the end of a shaft, which is what you have already created. I believe the existing length is already correct
