Oil cooler
whalenlg
Has thanked: 8 times
Been thanked: 115 times
I had to replace the oil cooler hoses, which meant removing the oil cooler. Looking back at my pictures, it looks like I just had to remove the power steering pump from the mounting bracket and move it out of the way without draining or disconnecting the ps hose fittings before I could get the oil cooler out. Yeah - it’s a pain!
1986 951 - Silicon Valley
Peter Sejersen
Thanks @whaling, I will give it a try with only removing the PS pump and then report back on how it went.
Thom
The First Carpoke!
Has thanked: 140 times
Been thanked: 156 times
Thanks all for your various inputs.
I am probably overconcerned. Ducting in and out is ok and in/outlets are upwards. Not ideal but no room to mount the larger oil cooler 90°.
'90 944 turbo
