Page 2 of 2
Re: Auxillary water pump for turbo
Posted: Sun Nov 12, 2023 7:54 pm
by dds28
I just linked your video on Rennlist where I had also posted a thread in the 944 turbo forum.
Posted: Wed Nov 22, 2023 5:57 pm
by mikee30
I had a similar issue and here is how I tackled it.
My test procedure was first to ensure the motor was getting power by grounding out the sensor (in my case the motor would run).
I had limited testing equipment so I opened my relay to visually inspect capacitors and took readings of the resistors. Everything looked fine, but since I had trouble sourcing a replacement relay, I just replaced the timer IC in the relay and the issue was solved. The IC was 1-2$ if I recall correctly.
Posted: Thu Nov 23, 2023 10:12 pm
by dds28
Where did you purchase the timer IC from and how difficult was it to replace it?
Posted: Wed Nov 29, 2023 5:44 pm
by dds28
Just to update, I replaced my relay with one bought on ebay. Now the aux pump works again. Thank you everyone for your help.
Posted: Fri Dec 01, 2023 12:12 pm
by mikee30
Just a note - if the relay for the waterpump aux motor is dead, before buying a replacement, you can try replacing the Timer IC on the relay circuit board for ~1$ (555 timer IC if I recall correctly)
Posted: Fri Dec 01, 2023 4:35 pm
by dds28
mikee30 wrote: Fri Dec 01, 2023 12:12 pm Just a note - if the relay for the waterpump aux motor is dead, before buying a replacement, you can try replacing the Timer IC on the relay circuit board for ~1$ (555 timer IC if I recall correctly)
Thank you for the info. I will go ahead and buy the Timer IC and replace it on my old relay and see if it fixes it.
Posted: Fri Dec 08, 2023 7:44 pm
by grantm951
I bought a 555 chip from digikey. I haven't made the repair yet.
Posted: Sat Dec 09, 2023 2:08 am
by dds28
How difficult is it to remove the chip and solder it to the board? Any special equipment needed?
Posted: Sat Dec 09, 2023 7:55 am
by whalenlg
It’s pretty easy. Generally solder, a soldering iron, solder sucker and some solder wick is all you need. Assuming that it’s a plastic 8 pin dip package.
