Big brake kit
Bergerac
Has thanked: 22 times
Been thanked: 129 times
Just be aware not all 17inch wheels have enough clearance for 996 calipers, mine didnt
cda951
Has thanked: 148 times
Been thanked: 83 times
Those 996TT front calipers are tempting---does anyone here know if these fit under any 17" wheels, or are 18" wheels 100% necessary?
Chris A.
---'86 944 Turbo track rat
---'74 Jensen-Healey roadster
---other stuff
ealoken
Has thanked: 46 times
Been thanked: 52 times
They fit under some 17", but if you use 350 disc, 18 is the only option.
blade7
Has thanked: 31 times
Been thanked: 23 times
ealoken wrote: Mon Jun 05, 2023 10:11 pm
blade7 wrote: Mon Jun 05, 2023 2:50 pmUK,
https://www.ebay.co.uk/itm/334900382910 ... media=COPY
Plenty of options 😊
Design 911 has adapters and discs.
Thanks for the info, though there's always a possibility they may need refurbing. Which is something I could do to my original late turbo calipers I suppose. Do you know if the big red copies Lindsey sell are any good? I'm already running 18" Gemballa wheels.
ealoken
blade7 wrote: Tue Jun 06, 2023 3:11 am
Plenty of options 😊
Hello, I have never seen or tested the copies, if they don't leak or flex while braking they should be ok.
But a used 996tt set of calipers are 500-1000$ used.
Evan
Has thanked: 10 times
Been thanked: 20 times
The calipers are likely Chinese-made Brembo replicas, often sold under brands like MEAT or JMP. Just confirm piston sizes match (usually 36/40mm). Cayenne discs are 330x32mm, so double-check rotor compatibility.
Maruscmn
Has thanked: 247 times
Been thanked: 88 times
IMHO I would stick with Brembos and stay away from the Chinese made ones. 996/997 calipers are abundant, cheap, and very easy to rebuild if necessary.
Mike
michaelmount123
Has thanked: 33 times
Been thanked: 184 times
Maruscmn wrote: Tue Aug 19, 2025 6:26 am IMHO I would stick with Brembos and stay away from the Chinese made ones. 996/997 calipers are abundant, cheap, and very easy to rebuild if necessary.
Mike
Agreed!
