How have you got on with the install? As per my earlier post regarding the Carlinkit t-box - I had been considering buying one and finally did from Amazon at £190. I haven’t had much time recently with having covid and work being busy, but had a quick go with it this morning.
Connected after about 30 seconds and showed up on PCM. You can install a sim in the box or tether to your phone. I tethered and all was fine. Also set phone to connect to the box via Bluetooth and that worked fine and I was able to make a call from my contacts with sound coming over the car speakers.
Opened Waze and maps - all good
So far, that’s all I’ve done, not tried “ok Google” or anything else (and all done while sat in the garage).
Adding Nav, track precision app, etc.
- Bill in Bama
- Has thanked: 16 times
- Been thanked: 155 times
I'm stuck until I get a GPS antenna installed. I thought all cars with carplay had the antenna but it's not so. I ordered one and after I get it installed I'll continue with downloading the files to my PCM.
'84 944, my first Porsche DBM
- Bill in Bama
Success! We got back together today and downloaded new files on my SD cards, remotely connected my car to his PIWIS so the cluster was enabled, and I downloaded the Nav and Map functions and the map files on my PCM and everything is up and running just like factory. I'm like a kid at Christmas after so many hours trying without success. If you have any tech sense at all this thing is a breeze to install on your PCM.
The trim is removed because I thought I was going to have to add a gps antenna but my car already had one, so I've put them back and everything is great now.
Hi Bill, this is Phil. I am glad it is working for you. If anyone has any questions, please post.Bill in Bama wrote: Thu Jul 21, 2022 4:06 pm Success! We got back together today and downloaded new files on my SD cards, remotely connected my car to his PIWIS so the cluster was enabled, and I downloaded the Nav and Map functions and the map files on my PCM and everything is up and running just like factory. I'm like a kid at Christmas after so many hours trying without success. If you have any tech sense at all this thing is a breeze to install on your PCM. Cluster.jpgHome screen.jpgPCM map.jpg
- Has thanked: 962 times
- Been thanked: 4161 times
Are you the brains behind this? Seriously cool project. Congrats!718socal wrote: Wed Aug 10, 2022 11:03 amHi Bill, this is Phil. I am glad it is working for you. If anyone has any questions, please post.Bill in Bama wrote: Thu Jul 21, 2022 4:06 pm Success! We got back together today and downloaded new files on my SD cards, remotely connected my car to his PIWIS so the cluster was enabled, and I downloaded the Nav and Map functions and the map files on my PCM and everything is up and running just like factory. I'm like a kid at Christmas after so many hours trying without success. If you have any tech sense at all this thing is a breeze to install on your PCM. Cluster.jpgHome screen.jpgPCM map.jpg
It is a group effort. I only put the pieces together. ThanksTom wrote: Wed Aug 10, 2022 11:07 amAre you the brains behind this? Seriously cool project. Congrats!718socal wrote: Wed Aug 10, 2022 11:03 amHi Bill, this is Phil. I am glad it is working for you. If anyone has any questions, please post.Bill in Bama wrote: Thu Jul 21, 2022 4:06 pm Success! We got back together today and downloaded new files on my SD cards, remotely connected my car to his PIWIS so the cluster was enabled, and I downloaded the Nav and Map functions and the map files on my PCM and everything is up and running just like factory. I'm like a kid at Christmas after so many hours trying without success. If you have any tech sense at all this thing is a breeze to install on your PCM. Cluster.jpgHome screen.jpgPCM map.jpg
- Bill in Bama
Yep, Phil is the GUY! I hesitated to use his name without permission but I invited him to Carpokes and he is now famous. It really is a cool mod, and very satisfying once installed.
- Bill in Bama
And I failed to mention he doesn't charge for his services.
- Bill in Bama
I see I also forgot that it turned out I did have the GPS antenna after all. Not sure why it didn't show as installed but it was there so it was a bit easier than would have otherwise been.Bill in Bama wrote: Mon Jul 18, 2022 6:02 am I'm stuck until I get a GPS antenna installed. I thought all cars with carplay had the antenna but it's not so. I ordered one and after I get it installed I'll continue with downloading the files to my PCM.
Yes it's a little bit of mystery for the GPS antenna. I have seen a couple 2017-18 Cayman with the GPS antenna installed and some without. All the MY2021 and 2022 GTS GT4 that I have worked on had the GPS antenna. It either comes with Carplay or Porsche Connect depending on your build.Bill in Bama wrote: Wed Aug 10, 2022 11:30 amI see I also forgot that it turned out I did have the GPS antenna after all. Not sure why it didn't show as installed but it was there so it was a bit easier than would have otherwise been.Bill in Bama wrote: Mon Jul 18, 2022 6:02 am I'm stuck until I get a GPS antenna installed. I thought all cars with carplay had the antenna but it's not so. I ordered one and after I get it installed I'll continue with downloading the files to my PCM.
For those interested, here is the link to download and flash your PCM to enable NAV, Carplay, Android Auto, Wi-Fi Hotspot, AUX, Track Precision App etc...
https://github.com/harman-f/MHI2_US_POG ... MU1476-AIO
Please check your version of PCM and see if it's supported first.
NAV requires a GPS antenna
MAP in cluster TFT display requires an LVDS cable and PIWIS coding.
Last, make sure that you are using a battery charger connected to your car before attempting this.
