Homelink
tohendy
Has thanked: 21 times
Has anyone mastered setting up Homelink on a 992? I have tried and tried but as far as I gotten is for it to show up on PCM so I can press and hold on my garage door's name. I cannot get it to automatically open at the set GPS location.
Any help would be appreciated.
2022 Carrera S Cabriolet
Been thanked: 4078 times
tohendy wrote: Wed Jun 29, 2022 6:47 pm Has anyone mastered setting up Homelink on a 992? I have tried and tried but as far as I gotten is for it to show up on PCM so I can press and hold on my garage door's name. I cannot get it to automatically open at the set GPS location.
I spent endless hours getting mine set up, and am not sure I could do it again or tell you how. The critical trick that I remember is that when you go to sync the remote, I had to drive down the street and be out of range of the garage receiver. Once it controlled the doors, it all but remembered the location on its own -- I think the red box came up asking if I wanted it to remember and it did. When you say automatically open, do you mean you want the doors to open, or just want the dash app to pull up the screen? Not sure it can automatically open the doors without pushing the button? I also programmed my diamond button on the steering wheel to pull up the garage door function on the PCM....
audi4t
Has thanked: 385 times
Been thanked: 298 times
I have mine set up so that as I approach my home the homelink activate screen pops up on pcm.
I may be wrong but I don’t think there is a way or intent for your garage door to automatically open as you approach - probably a safety feature.
You have to take a conscious action to open the door - which makes sense really.
I have found homelink operation to be very sensitive to the cars physical location, a few feet makes a difference.
Also like Tom I have the diamond button on the steering wheel set up to activate homelink. Homelink activation works best with a momentary tap NOT an extended hold.
toddinmd
Has thanked: 31 times
Been thanked: 59 times
Like Tom said, the homelink will only automatically popup on the PCM, it does not open the door.
In our Taycan, it has multiple wildcard buttons (diamonds), I'm using the one on the dash to activate the homelink, just a momentary tap activates the door, a long press will not work. Counter intuitive compared to other cars, that need a long press.
2018 991.2 GT3
2022 Taycan CT4
elm310
Has thanked: 271 times
Been thanked: 92 times
Mine was really easy, it took me literary 5 minutes to do. What are you having trouble with? Maybe I can make a video on how to do it?
Eric
2022 911 Carrera 4 GTS
2009 BMW e92 M3
2014 BMW f10 535i
2017 Nissan Frontier SV
2019 Yamaha AR210 Jetboat
Newport IRL
Based on comments I had previously read, I was expecting to have trouble programming mine, but it also only took me five minutes to do it and I programmed the steering shell diamond key and it works great. I followed the instructions in the owner manual.
Newport IRL wrote: Fri Jul 01, 2022 8:35 pm Based on comments I had previously read, I was expecting to have trouble programming mine, but it also only took me five minutes to do it and I programmed the steering shell diamond key and it works great. I followed the instructions in the owner manual.
What year is your car? I'm wondering if it's gotten better for the '22+ models?
raykhublal
Has thanked: 40 times
Been thanked: 24 times
Porsche homelink setup seems really difficult compared to other makes…had a hard time setting mine up on my 991.2 also.
Jeankysti
Has thanked: 5 times
Been thanked: 11 times
I was able to setup my homelink on a 991.2 within 5 minutes or so, very simple.
991.2 Carrera S
Instagram: @jeankysti
www.realstreetperformance.com
tohendy
Jeankysti wrote: Wed Jul 06, 2022 2:39 pm I was able to setup my homelink on a 991.2 within 5 minutes or so, very simple.
I'm thinking it may depend on your garage door opener as I had to call Homelink to get my 991.2 set up after following all of Porsche's instructions.
