The AC on my car never worked since I got it, after checking pressures I found the system completely empty. I pulled vacuum but that lasted about 5mins, so major leak somewhere.
I put about 100lbs of air and started to look for a leak with water and soap, and of course it couldn't be a simple o-ring somewhere, instead the compressor is leaking. Looking under the car from the center of the car I can see bubbles from the top area of the compressor. I am attaching a picture that shows the location.
Any ideas? Is this a new compressor deal, or is there something up there that can be tighten.
AC Compressor Leaking
- Has thanked: 256 times
- Been thanked: 251 times
I don't have your car, but do have the same compressor. If that's the hose manifold connection, it bolts to the compressor and does seal with o-rings under the manifold plate, so it's a relatively easy fix. Use modern green o-rings of course.
Over 25 years ago I did the R-134a conversion on my car, and didn't realize there are o-rings there. The initial AC charge was great for almost a day before there was a pretty spectacular discharge at the mounting flange. The new POE oil pretty much decimated the old buna o-rings from its R12 days. A lesson not easily forgotten. Fixed with new pieces, properly torqued manifold plate, another evacuation and refill, and its been reliably cold ever since with not a lot of attention.
SoCal 928 Group Cofounder
I agree the leak appears to be stemming from the compressor's bolt-on manifold connection. The original o-rings were made of black rubber that hardens over time.
Check out part number: 94412693501, often listed as "A/C O-Ring (20 X 2.5 mm) for Compressor Service Fittings."
If you're going generic, the o-ring specs are:
- Inside Diameter (ID): 20.0 mm
- Cross-Sectional Diameter (CS): 2.5 mm
- Outside Diameter (OD): 25.0 mm
- Has thanked: 948 times
- Been thanked: 4046 times
^^what he said^^
See pictures from my old compressor. Your leak is almost surely from the o-rings under that bolt-on manifold -- which I always think looks like an elephant's face
Good work! Glad it was that simple!shft22 wrote: Mon Jun 29, 2026 11:10 am Replaced all four o-rings, did all the good stuff to get the system as it should and she is cooling ok. It was 91F outside when I took this picture.
Thank you all for your help.
If you are the type to fixate on things for no practical reason, know that you could get it another 15-20 degrees colder still.
- PSU_Crash
- Has thanked: 192 times
- Been thanked: 114 times
Now I can't un-see it!
I'm about to dive into my AC as well. It works .. mostly. I'll start a thread soon
'86 Zermatt Silver 944 N/A
