AC Compressor Leaking
shft22
Has thanked: 4 times
Been thanked: 9 times
The AC on my car never worked since I got it, after checking pressures I found the system completely empty. I pulled vacuum but that lasted about 5mins, so major leak somewhere.
I put about 100lbs of air and started to look for a leak with water and soap, and of course it couldn't be a simple o-ring somewhere, instead the compressor is leaking. Looking under the car from the center of the car I can see bubbles from the top area of the compressor. I am attaching a picture that shows the location.
Any ideas? Is this a new compressor deal, or is there something up there that can be tighten.
Screenshot 2026-06-20 at 12.55.13 PM.png (2.68 MiB) Viewed 96 times
Has thanked: 256 times
Been thanked: 251 times
I don't have your car, but do have the same compressor. If that's the hose manifold connection, it bolts to the compressor and does seal with o-rings under the manifold plate, so it's a relatively easy fix. Use modern green o-rings of course.
Over 25 years ago I did the R-134a conversion on my car, and didn't realize there are o-rings there. The initial AC charge was great for almost a day before there was a pretty spectacular discharge at the mounting flange. The new POE oil pretty much decimated the old buna o-rings from its R12 days. A lesson not easily forgotten. Fixed with new pieces, properly torqued manifold plate, another evacuation and refill, and its been reliably cold ever since with not a lot of attention.
SoCal 928 Group Cofounder
NC944er
Been thanked: 20 times
I agree the leak appears to be stemming from the compressor's bolt-on manifold connection. The original o-rings were made of black rubber that hardens over time.
Check out part number: 94412693501, often listed as "A/C O-Ring (20 X 2.5 mm) for Compressor Service Fittings."
If you're going generic, the o-ring specs are:
  • Inside Diameter (ID): 20.0 mm
  • Cross-Sectional Diameter (CS): 2.5 mm
  • Outside Diameter (OD): 25.0 mm
Green nitrile is best when converting to R-134a. Pelican Parts and FCP Euro have them for about $1.00 apiece, you'll need 4 o-rings total. Coat lightly with refrigerant oil during installation. The A/C compressor should be removed for clear access to the hex key bolts, so you might as well replace the o-rings for the barrier hose connections and add in a new receiver drier while you're there.
Has thanked: 948 times
Been thanked: 4046 times
^^what he said^^
See pictures from my old compressor. Your leak is almost surely from the o-rings under that bolt-on manifold -- which I always think looks like an elephant's face :angel:
shft22
Well sir, you were right on the money. Take a look, two of the four o-rings were completely destroyed.
shft22
Replaced all four o-rings, did all the good stuff to get the system as it should and she is cooling ok. It was 91F outside when I took this picture.
Thank you all for your help.
shft22 wrote: Mon Jun 29, 2026 11:10 am Replaced all four o-rings, did all the good stuff to get the system as it should and she is cooling ok. It was 91F outside when I took this picture.
Good work! Glad it was that simple!
If you are the type to fixate on things for no practical reason, know that you could get it another 15-20 degrees colder still. :shifty:
shft22
This first round was to be sure the system is working and not leaking. I am trying to get the car to a some what comfortable driving stage to enjoy it and at the same time see what else comes up.
PSU_Crash
Has thanked: 192 times
Been thanked: 114 times
Tom wrote: Sat Jun 20, 2026 11:46 am which I always think looks like an elephant's face :angel:
Now I can't un-see it! :lol:
I'm about to dive into my AC as well. It works .. mostly. I'll start a thread soon
PSU_Crash wrote: Mon Jun 29, 2026 4:57 pm
Now what if I told you the arrows were eyebrows... :shifty:
