Running out of projects!
A forum for the 3.6 liter Air-cooled Cars
rchaas
Has thanked: 6 times
Been thanked: 10 times
I have owned my 1995 C2 for about two months now and it's been a great experience so far. I love the ability to diy most anything on this car, depending on one's capabilities and willingness to dive in. I'm not an experienced mechanic by any means, and the really big jobs (engine out, seals, transmission repair, etc), I leave to my local independent Porsche mechanic, who has been incredibly helpful in enabling my hobby and projects!
a list so far:
new tires, bent wheels replaced with refurbished Cup 2's
corner balance and alignment (at the shop)
brake flush
air and cabin filters replaced (ugh, the cabin ones were gross!)
gear fluid change (don't think it had ever been done)
replaced locking lug nuts
new driver side door seal and door handle gaskets
replaced funny looking kenwood aftermarket radio with a Continental TR7412
Rennline phone holder
removed tachometer, cleaned haze behind the glass and replaced
repaired broken fog light mounting tab, front right
repaired broken plastic door pocket mounting brackets (both sides)
new floor mats
replaced rear decklid struts (what a pain!)
FD pad keeper
leather reconditioning, dye and topcoat applied to seats, steering wheel and shift knob, looks great!
Numeric short shift kit (discovered the front guide rod on oem setup was hanging free, failed bushing!)
RS motor mounts
replaced cassette holder in rear center console with cup holder
paint correction, ceramic coated body and wheels (CSL, Exo V5, C5 on wheels)
Pending:
LED projectors/bulbs for headlights, coming from UK
Things that will be needed eventually, but ok for now:
small timing chain cover and rear main seal leaks, hopefully they won't become big leaks too soon
clutch linkage, master/slave replacement (occ clutch pedal partial return)
So, what else should i attend to?
Robbie
2020 Chalk Macan GTS
2017 White Metallic 991.2 C2S
1995 Midnight Blue 993 C2
Has thanked: 4446 times
Been thanked: 2413 times
@rchaas
Nice to see what all you've done - good summation and great work too!
I like the blue - blues are always great choices in my book. Your C2 is beautiful. :thumbup:
Has thanked: 520 times
Been thanked: 262 times
@rchaas
YOWWWWZA that's a beautiful car!
rchaas
Any of you 993/964 owners installed numeric pedals? I am thinking about those as well....
Robbie
rchaas wrote: Sun Feb 15, 2026 1:27 pm Any of you 993/964 owners installed numeric pedals? I am thinking about those as well....
No experience with Numeric on a 993 but the ones I installed on my GT4 are superb. High quality, look great and work wonderfully. Huge improvement over flimsy OEM pedal covers that came with the car.
viewtopic.php?t=1733&start=340#p26920
rchaas
Update! I installed Bi-LED projectors and Osram high beam bulbs, huge improvement. I can now drive at night, confident I can see and be seen! Sourced from emtuning.co.uk and highly recommended.
Pic doesn't do justice to how much brighter.
Half the job done here:
Robbie
mid_shift
Any feedback on the numeric shift kit? I have one sitting around that I haven't installed yet, purchased based off of good feedback on their watercooled shifters.
Also, definitely replace front control arm bushings with some polybushes and add the steering rack brace. I have straight poly, but would go with the Powerflex polybronze ones if I were doing it again (Powerflex ones weren't on the market when I did them initially). Makes a big difference on steering feel. If your suspension is tired, I like my PSS10 coilovers as a nice streetable option that aren't too spendy.
Mcporguy
Very nice. Midnight blue?
Porsche classic radio, speaker & amp upgrade?
Fister muffler modification?
PSS10 and euro height
rchaas
Yes, midnight blue metallic!
I have PSS10 ‘s up front, rears are ok for now.
The numeric shift kit is an excellent upgrade. It’s well built, install is straightforward and I like the guide rod delete conceptually. I used the max reduction and left the oem selector rod in place. Also used the stock leather cover so the interior appearance remains unchanged.
I am not crazy about out the Porsche classic radio since the screen is so small, and frankly, I rarely listen to music when driving the car. The continental head unit I installed works great, allows streaming from my phone. Perhaps some speaker upgrades might make sense.
The fister exhaust is on the consideration list for sure. Also, my calipers need a refinish/repaint. I’ve done that before with rattle can caliper paint that didn’t really hold up so thinking about a professional full caliper resto.
Yesterday I installed the Bergville FX T-LED kit so now all the lights are bright and visible. Another nice upgrade.
Thanks for the suggestions !
Robbie
rchaas
I also recently had the clutch master and slave cylinders along with the updated intermediate lever replaced. No more sticky clutch!!
I will look into front control arm bushings. Sounds like a good one. Any squeaking with the poly bushings?
Robbie
